1. Duncan Sharp's Avatar
    I've seen there are a few third party chargers that can charge the note 10 plus at 45w but haven't seen anything on car chargers
    Any suggestions?
    08-23-2019 12:26 PM
  2. Duncan Sharp's Avatar
    I bought this but think it's only giving up 15w
    Nekteck USB C Car Charger with... https://www.amazon.com/dp/B075WQQG7C...cUvbUpU6617545
    08-23-2019 07:22 PM
  3. Mooncatt's Avatar
    Samsung doesn't use the standard Power Delivery specification to achieve 45W. They use a proprietary spec called Programmable Power Supply. Their 45W charger is PD rated with the addition of PPS. PD uses 15V@3A, but PPS uses 10V@4.5A. It'll likely be a while before third party chargers start having the PPS protocol, and a standard PD rated supply will not give 45W to the 10+.
    strikeIII likes this.
    08-23-2019 07:58 PM
  4. Duncan Sharp's Avatar
    Thanks.
    Annoyingly I bought it before the specs were released about the notes 45w power requirements
    08-23-2019 08:00 PM
  5. Mooncatt's Avatar
    Thanks.
    The specs had been released, you just have to look for them. Most of three confusion is people just assumed and didn't bother double checking.
    08-23-2019 08:18 PM
  6. Hermes Hidayat's Avatar
    Erm im currently using my Huawei SuperCharger for my N10+ when im in the car. Seems okay...
    08-23-2019 09:35 PM
  7. Duncan Sharp's Avatar
    Guessing only 15w?
    08-23-2019 09:42 PM
  8. theshaz's Avatar
    With that thought.....
    If the car battery was dead and we plugged a Note 10 into the 12v
    Can we start a car?
    /s
    kevinpleasants likes this.
    08-23-2019 10:11 PM
  9. Duncan Sharp's Avatar
    Easy! I've powered lights off a car battery
    08-23-2019 10:14 PM
  10. MRBULLRED's Avatar
    My truck, as alot of new vehicles, has 115v outlets. I'm just gonna plug in the home brick there. Problem solved.
    08-24-2019 08:18 AM
  1. Should I reformat my SD card in the Note 10+ ?
    By felloffthetruck in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-29-2019, 02:48 PM
  2. Why is my phone zooming in on wallpaper at random times?
    Last Post: 08-23-2019, 08:33 PM
  3. Always on display not working unlocked version on t-mobile
    By dario12v in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-23-2019, 11:51 AM
  4. Thorough Walkthru of Galaxy Note 10+
    By Codeworks in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-23-2019, 10:48 AM
  5. How to upgrade os on a network unlocked phone
    By Khafe in forum Samsung Galaxy Note 8
    Last Post: 08-23-2019, 10:42 AM
