1. jessesmith8888's Avatar
    Listening to audiobooks in my car and Bluetooth headset sounds raspy. Didn't have this problem with my last phone.
    08-23-2019 02:29 PM
  2. jlangner's Avatar
    I haven't noticed anything from youtube music in my car or on Buds.
    08-23-2019 03:17 PM
  3. CKwik240's Avatar
    Mine is fine as well. Did you try different media? And I would try playing through the USB C headphones as well to confirm if it's actually a Bluetooth issue.
    08-23-2019 07:07 PM
  4. amyf27's Avatar
    Mine has been great so far I have connected it to Android auto and also just buy Bluetooth without issue
    08-23-2019 07:37 PM
  5. jrham's Avatar
    Hey did you figure anything out? My 10+ has been sounding like that lately.
    01-23-2020 12:45 AM
  6. Terry1996's Avatar
    I too am having an issue. I have to turn the volume way up on the car to hear the music. I have the volume on the phone turned all the way up. Is there a setting that I can enable to fix this? The EQ is set to flat the adaptive audio is off and the Dolby Atmos setting is off as well. I am torn on whether the bluetooth on this phone is borked or I should get a different phone. Thanks in advance!
    01-31-2020 03:08 PM
  1. Best photo gallery app for the S10+
    Last Post: 08-23-2019, 06:10 PM
  2. Anybody else order the at&t aura blue Note 10+
    Last Post: 08-23-2019, 02:50 PM
  3. TTS resets voice data for some reason
    Last Post: 08-23-2019, 12:43 PM
  4. Replies: 0
    Last Post: 08-23-2019, 05:33 AM
