1. rushmore's Avatar
    I had the Note 9 for a year and except for the curved edges, was fantastic
    Hitting 12 hours with the Black Note 10+ 512 Verizon model. Observations:
    -Display is so big, the punch hole is not an issue
    -Display is amazing and even better than the N9
    -The N10+ in power saver mode is faster than the N9 when not in power saver mode
    -Signal reception seems the same
    -Audio quality from the USB C is the same the N9- which is great- Still, no 3.5 jack sucks.
    -Bluetooth quality and range seems at least as good as the N9 (for bluetooth is is great)
    -Speakers sound a little better than the N9
    -The corners and edges are less curved- that and the extra portrait width IMO makes a big difference for content. Simply put, curved corners and edges don't work well for media designed for flat displays.
    -Very smooth, but then again so was the N9
    -Low light pics are better than the N9
    Since the N10+ has a faster display and bigger chipset, but only 7.5% bigger battery, I'll be happy if battery life is the same as the N9, which for me was great.
    SZQnl and bandofbrothers2112 like this.
    08-23-2019 10:39 PM
  1. How to change payment method in samsung galaxy store?
    Last Post: 08-27-2019, 09:59 PM
  2. Replies: 4
    Last Post: 08-23-2019, 11:11 PM
  3. Best transfer of calendar from Note8 to Note10+ ?
    By hummingbirdhill in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-23-2019, 10:00 PM
  4. Google Assistant to send text
    By Seki-Kun in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-23-2019, 09:20 PM
