1. dutchc's Avatar
    On my Note 8 I can unlock the phone with a long press of the home button. I don't see that option on my Note 10 plus. Anyone?
    08-25-2019 12:28 PM
  2. fernandez21's Avatar
    I guess you can do something similarly, but with the fingerprint reader.
    08-25-2019 12:29 PM
  3. mustang7757's Avatar
    The note 10 doesn't have a home button on lock screen, it's same with the S10.
    08-25-2019 12:34 PM
  4. JeromeM's Avatar
    You just have to double tap the screen should work or if you are using FPS just use that it will unlock.
    08-25-2019 04:31 PM
  1. Anyone upgrade from N9 to the N10?
    By DanielLoreti in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-27-2019, 08:44 PM
  2. How do i add a new cloud to ny existing account
    Last Post: 08-25-2019, 03:34 PM
  3. Similar objects function - how to get rid of it
    By Android Central Question in forum Huawei P20 & P20 Pro
    Last Post: 08-25-2019, 02:08 PM
  4. P30 Pro to Note 10+
    By Hermes Hidayat in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-25-2019, 11:11 AM
  5. how to delete or disable device maintenance.
    Last Post: 08-25-2019, 09:19 AM
