1. AZwldcats's Avatar
    2 Mornings in a row I have woken up to a factory lock screen and upon unlock get a phone starting phone visual with about a 5 sec delay before I can use it.
    And uptime shows it is rebooting between 3 and 4 am.
    To add it has never rebooted at any other time.
    Is there an automatic reboot setting somewhere. I had a Sunday Night weekly reboot set on my N9 but cannot find it on my N10+
    08-25-2019 12:24 PM
  2. pool_shark's Avatar
    There is an auto restart setting in device maintenance.
    08-25-2019 12:40 PM
  3. darkestred's Avatar
    Nope.
    08-25-2019 12:42 PM
  4. mustang7757's Avatar
    I agree with pool shark in device maintenance app there's a setting to turn off auto restart.
    08-25-2019 12:50 PM
  5. PinkLipstick's Avatar
    device care, tap the menu, auto restart, toggle off and you should be good to go.
    toenail_flicker likes this.
    08-25-2019 01:00 PM
  6. stuckingoo's Avatar
    Make sure you have the update installed. It's possible that the install became corrupted.
    08-25-2019 01:03 PM
  7. AZwldcats's Avatar
    Thanks for the location of auto restart.
    That did carry over from my 9 but was only supposed to be on Sundays. I turned it off and let's see what happens tonight I guess.
    I did install the update the day I got it so only time will tell I guess. Does your Note 10+ reboot every night?-screenshot_20190825-121943_device-20care.jpeg
    mustang7757 likes this.
    08-25-2019 02:21 PM
  8. durandetto's Avatar
    Might have had the update install Friday night then the auto restart last night.
    08-25-2019 03:47 PM
  9. AZwldcats's Avatar
    There's only been one Update though right? Because I did one as soon as I got the phone before I restored everything to the new 1.
    Nostromo79 likes this.
    08-25-2019 05:03 PM
  10. KruseLudsMobile's Avatar
    My Note 8 rebooted on it's own twice on the day before I got the Note 10+...THEN later that day a message came up saying I should reboot the phone because it had not been rebooted in 7 days.... LOL
    08-25-2019 05:23 PM
  11. evohicks's Avatar
    I had my Note 9 restart every Sunday at 3am and the day after I got my Note 10+ (Friday) it had rebooted overnight, I checked the auto reboot settings and it had set to Friday 3am and not Sunday, must have been a smart switch thing.
    08-25-2019 05:50 PM
  12. WhippetRun's Avatar
    Yeah j notice that too,its weird my note8 never did it like that, it would just make you use a different method (pattern) to log in.
    Anyway, thanks everyone! I had the same question
    It is under the device maintenance section, to the right with the three dots.
    What I like is that I can pick more than one day, with the note 8 I could only choose 1
    08-31-2019 10:58 AM
  13. anon(10274434)'s Avatar
    Thanks for the info - mine is set to OFF since I reboot once a twice a week out of habit.
    08-31-2019 11:26 AM
  14. o4liberty's Avatar
    I have mine set to reboot twice a week
    08-31-2019 04:34 PM
  15. Gary02468's Avatar
    I only reboot when the firmware updates, unless something stops working properly. I know Samsung recommends rebooting weekly, but that's kind of an admission that the phone's design is inadequate. In the absence of resource leaks or corruption, there's no need for periodic rebooting.
    09-01-2019 06:32 AM
  1. Note 10+ Battery drain issue
    By Koolspy in forum Ask a Question
    Last Post: 08-26-2019, 11:54 AM
  2. Note 10 and DEX with Windows computer connection
    By Casey Cheung in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-26-2019, 09:34 AM
  3. audio on 10s
    By joan jones in forum Ask a Question
    Last Post: 08-25-2019, 03:03 PM
  4. P30 Pro to Note 10+
    By Hermes Hidayat in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-25-2019, 10:11 AM
