1. ivanwi11iams's Avatar
    Curious, does the Note 10+ have Edge Lighting?
    If so, do you use it?
    08-25-2019 04:25 PM
  2. Roustermiller's Avatar
    Yes it has it and I use it
    ivanwi11iams likes this.
    08-25-2019 04:29 PM
  3. cwbcpa's Avatar
    Yes and yes.
    08-25-2019 04:38 PM
  4. jdrake73's Avatar
    Yes, especially since the led indicator is gone.
    Nostromo79 and ivanwi11iams like this.
    08-25-2019 04:49 PM
  5. phone-a-holic's Avatar
    I use it. Used it on my note 9 too
    08-25-2019 04:54 PM
  6. Serkle K's Avatar
    Yes, and I've been using all the Edge features since I got the S7E (was originally the Note7), and I'm actually more disappointed in the edge features they've been taking away.
    08-25-2019 05:29 PM
  7. Dimas de Leon's Avatar
    I remember in other phones, not sure which one, I could pick the lighting color depending on the app the notification was coming from, for example, I had yellow for Snapchat,a green for Whatsapp, blue for Facebook, etc..... they took that ability away in the Note 10 +? It seem I can only pick one color for ALL notifications.
    08-25-2019 05:30 PM
  8. alodar101's Avatar
    I reset device yesterday and edge lighting turned on. I was surprised when it came on. I smiled because it really looked cool...
    08-25-2019 05:51 PM
  9. ivanwi11iams's Avatar
    I’ve now been using it for a few hours.
    Actually, not bad at all...
    08-26-2019 04:31 AM
  10. algiii's Avatar
    You can select color per app in options
    08-26-2019 04:40 AM
  11. ivanwi11iams's Avatar
    Clearly I missed this the first time I was in settings.
    I will look into it now Thanks for sharing...
    [IMG=986x949]https://uploads.tapatalk-cdn.com/20190826/a2462a2a2876913045895b6f72094666.jpg[/url]
    nuangel2 likes this.
    08-26-2019 06:37 AM
  12. ivanwi11iams's Avatar
    Oddly, on my Note 9, with the latest updates (ATT), I do not have the option to edit colours per application.
    Weird that.
    Where exactly in options does one go to?
    08-26-2019 06:44 AM
  13. sweetypie31's Avatar
    Weird that.
    When you go into the edge lighting settings click edge lighting style, then color and then click custom color.
    08-26-2019 07:00 AM
  14. ivanwi11iams's Avatar
    My my, talk about hidden!
    Thanks for sharing...!
    sweetypie31 likes this.
    08-26-2019 07:03 AM
  15. sweetypie31's Avatar
    To answer the original question when ever I finally get the 10 I plan on edge lighting. It comes in handy and ive found I like it better than the led light.
    08-26-2019 07:05 AM
  16. Dimas de Leon's Avatar
    Thanks, I had to download the edge lighting app via the Galaxy Store. I don't think the edge lighting settings you find in the settings menu don't give you the color options.
    08-26-2019 04:12 PM
  1. IMPORTANT-I can see fingerprint reader hardware when phone in direct sun light!!!
    By Lepa79 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-12-2019, 08:16 AM
  2. Edge Panels
    By zoggybottom in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-23-2019, 08:18 PM
  3. just need holey light now
    By JoBudden in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-22-2019, 09:55 PM
  4. Touch Screen malfunctioning but working, red light blinking when charging ZTE
    Last Post: 08-21-2019, 10:53 AM
  5. How do i turn off all the double taps on galaxy s7 edge
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 08-17-2019, 11:23 AM
