The notification number is not showing up. The text are there just no indication. Anyone else with this issue?
I am. I was just about to start a thread because I'm not getting badges for any of my apps.
Home screen is grayed outHey, make sure this is turned on, you can find it by going to options/display/homescreen. Scroll down and you should see it
Homescreen is grayed outHey, make sure this is turned on, you can find it by going to options/display/homescreen. Scroll down and you should see it
I figured out my issue. I forgot to turn on the notification badges in nova. OP are you using nova launcher? That could be it.
They got rid of Tesla. The badges are now baked into nova. In the nova settings it says notification badges as an option.I have Nova prime and was unable to find TeslaUnread anywhere so I'm not using Nova for now.
Sorry I didn't see your post asking how to get to it. I'm glad you got it fixed.OK I figured out that my Nova Prime was not activated. Its on now and the badges are there. Crisis is over. LOL. Thanks everyone.
