1. ivantwilliams's Avatar
    Morning all, me again...
    Anyone here using an unlocked Note 10+, with AT&T?
    If so, any issues thus far?
    Also, I know with the unlocked version, you simply do not get all the carrier apps.
    But, besides being able to use the device on 'any' GSM carrier, any other benefits I have not thought about?
    Thanks
    08-30-2019 06:30 AM
  2. geraldem's Avatar
    Thanks
    Hi. I had the unlocked for a few days. The biggest issue was the lack of VoLTE, HD Voice and Wifi calling. For me VoLTE was the biggest issue, as it was like have a Turbo Porsche that had engine limits. And the only way to get those services is to flash ATT firmware..and that seemed like the results were mixed.
    So I sent back my unlocked to Samsung...with all the $200.00 credit stuff. Then went to BB and got ATT branded N10+. Been really happy with it, other than 2 days of bad battery drain due to a bad update.
    ivantwilliams and Rukbat like this.
    08-30-2019 06:58 AM
  3. ivantwilliams's Avatar
    I ended up going with the AT&T variant. The word is you can flash the Unlocked version, etcetera.
    But, in all honesty, I simply cannot be bothered
    08-30-2019 07:36 PM
  4. Gdwheel's Avatar
    I did this in the past. Learned the hard way. You have to pay the extra to get the AT&T variant so you can have the full use of a phone on AT&T.
    08-30-2019 07:39 PM
  5. asimon1006's Avatar
    Can someone send me a link with the step by step instructions to flash my unlocked samsung note 10+ on att?
    09-14-2019 09:14 PM
  6. mustang7757's Avatar
    I made a sticky with Ruben
    https://forums.androidcentral.com/sa...-firmware.html
    09-14-2019 09:16 PM
  7. fernandez21's Avatar
    Hmmm..... does anyone know if you take the at&t variant and flash the stock unlocked firmware, do you still get wifi calling, volte, ect? Since it seems at&t blocks those services using your imei?
    09-15-2019 03:20 AM
  8. mustang7757's Avatar
    I'm not the unlock using my Att sim
    No WiFi calling , don't see volte .. but overall I like the unlocked over carrier version.
    Larry Holbert likes this.
    09-15-2019 09:10 AM
  9. _YoKolorMeBadd's Avatar
    I had an unlocked samsung device once. Like everyone said no VoLTE, Wifi calling.. Back then that was something I needed since I had horrible reception at my former residence. I now end up just getting the carrier branded phones.
    09-15-2019 09:35 AM
  10. ivantwilliams's Avatar
    You know, I have never used WIFI calling. To me, I feel as if I would probably get cutoff, while talking.
    Alas, I digress...
    mustang7757 likes this.
    09-15-2019 08:50 PM
  1. WTS: Samsung Galaxy LTE Unlocked 46mm watch
    By amyf27 in forum The Marketplace - Buy, Sell & Trade
    Last Post: 10-06-2019, 01:42 AM
  2. WTS: Note 10 + Spigen Ultra case
    Last Post: 09-09-2019, 11:14 PM
  3. Samsung Notes vs S Notes?
    By Ultra Male in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-03-2019, 05:33 PM
  4. Galaxy Note 1 - Hangs on start up screen
    Last Post: 09-01-2019, 11:37 AM
  5. Where is the video editor app that's on the Note 10?
    Last Post: 08-30-2019, 07:14 AM
