1. cthebigpicture's Avatar
    This (Note 10+) is my first phone with an in screen finger print sensor and I hated it. To a point that I changed to face unlock yesterday.
    Got this video off reddit this morning and to my surprise it works amazingly well. Check it out. This is how you should set up your finger prints.
    PS (yes original video is for S10 but works with Note as well)
    08-30-2019 06:44 AM
  2. pool_shark's Avatar
    Mine works flawlessly without tricks.
    All I do is press firmly and release quickly.
    08-30-2019 06:57 AM
  3. Jona005's Avatar
    Surprisingly mine has worked perfectly thus far.
    08-30-2019 07:39 AM
  4. Lepa79's Avatar
    ↑↑↑ This.
    The video is interesting none the less. I'm happy with how mine been working. No issues
    pool_shark likes this.
    08-30-2019 07:43 AM
  5. cthebigpicture's Avatar
    Mine just wasn't reliable. Most of the times it worked but sometimes it didn't. Enough for me to have moved away from it. Glad its working out for everyone
    08-30-2019 08:03 AM
  6. Shelacios's Avatar
    I've discovered that mine does not work well if my finger is totally dry (like needs lotion dry after hand washing) . If there is just tiny bit of moisture to my finger it works fast and efficiently. If my finger is dry it hardly works at all. Lesson - use lotion after washing hands.
    dforslund likes this.
    08-30-2019 08:19 AM
  7. ZOMMBIE1's Avatar
    I'd have to say this finger print sensor has improved over the S10+. I don't use screen protectors and using without a screen protector improves it also.
    08-30-2019 08:41 AM
  8. nuangel2's Avatar
    My fps works well no problem here
    08-30-2019 09:05 AM
  9. sp44's Avatar
    I would assume using it without a screen protector would be a little better.
    08-30-2019 09:28 AM
  10. ROE_HUNTER's Avatar
    Wow, I was holding down until the screen opened, it actually seems faster if I do this ↑↑↑
    pool_shark and larman2001 like this.
    08-30-2019 09:54 AM
  11. rabernet's Avatar
    I posted this same video here yesterday about the FPS.
    08-30-2019 10:20 AM
  12. cthebigpicture's Avatar
    Sorry didn't see the post.
    Great tip right? The FPS works great for me now.
    rabernet likes this.
    08-30-2019 03:00 PM
  13. dario12v's Avatar
    Mine works great actually
    08-30-2019 07:19 PM
  14. 7airwrecka7's Avatar
    Thank you! I just did it and it works so much better!
    08-31-2019 07:10 AM
  15. Dimas de Leon's Avatar
    Crazy, it worked a lot better for me too.
    08-31-2019 07:38 AM
  16. sulla1965's Avatar
    Yeah mine didn't need any tricks either. Worked great right out of the box
    08-31-2019 01:01 PM
  17. o4liberty's Avatar
    I have tried a few different methods and it has gotten better but compared to my pixel 3 it's still very slow. I have watched every video and read everywhere I could but still not up to par for me hopefully there will be an update.
    EMGSM likes this.
    08-31-2019 01:07 PM
  18. EMGSM's Avatar
    I agree. It seems to work more consistently that the S10+.
    bandofbrothers2112 likes this.
    08-31-2019 01:13 PM
  19. bandofbrothers2112's Avatar
    Sounds like Samsung has then listened to the feedback from owners of the s10 phones and possibly further improved the fps on the Note 10 phones.
    09-01-2019 01:16 AM
  1. Replies: 7
    Last Post: 09-02-2019, 08:57 PM
  2. How to change Samsung S10 - How to display Settings from List view to Tabs view?
    Last Post: 08-30-2019, 08:23 AM
  3. How to delete user certificate from KNOX
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 08-30-2019, 08:19 AM
  4. Where is the video editor app that's on the Note 10?
    By Ultra Male in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-30-2019, 07:14 AM
  5. How to delete user certificate from KNOX
    Last Post: 08-30-2019, 04:01 AM
