1. alphaac's Avatar
    Anyone else not hearing notifications from the phone whenever paired Bluetooth earbuds are connected? I can only hear my notifications (text received, new email etc.) through my buds and not the phone. That's a problem when the buds are not in my ear... Disconnect the Bluetooth and notification sounds resume playing through the phone.
    08-31-2019 08:27 PM
  2. burrzoo's Avatar
    I believe that this is by design and has been that way (forever) once the BT headphones are connected.
    Update:
    Try this:
    go to settings > sounds and vibrations > advanced sounds settings > separate app sound > App > select the app in the list, if not in the list click add apps and find it >back up one screen> select on at the top> audio > device and select bluetooth device instead of phone, its backwards , send a test text
    08-31-2019 10:03 PM
  3. pool_shark's Avatar
    Yep, same thing on my note 8.
    08-31-2019 10:04 PM
  4. alphaac's Avatar
    Update:
    Try this:
    Thanks for the suggestion, but it didn't work for me. No notification sounds from phone, only through the connected bt buds.
    08-31-2019 10:39 PM
  5. burrzoo's Avatar
    So sorry. Check the Samsung forums. Maybe there are other ways.
    08-31-2019 10:53 PM
  6. pool_shark's Avatar
    I never found anything.
    I have some BT earbuds that would randomly turn themselves on at night and I would miss phone calls while on call. I had to start setting tasker to turn BT off at night.
    I don't recall this on my note 5. I assume an OS update implemented this.
    08-31-2019 11:05 PM
  7. burrzoo's Avatar
    Apparently things changed when Android Pie was introduced.
    08-31-2019 11:09 PM
  1. Anybody concerned about phone prices jumping up from the trade war?
    By J Dubbs in forum General News & Discussion
    Last Post: 09-02-2019, 12:26 PM
  2. getting "Google Play Services are not supported by your device" Galaxy Tab-A
    Last Post: 09-01-2019, 11:08 PM
  3. Replies: 4
    Last Post: 09-01-2019, 10:54 PM
  4. How do i transfer a qlink wireless service to another qlink phone?
    Last Post: 09-01-2019, 10:49 PM
  5. Bluetooth volume controls trols
    By adjg in forum Samsung Galaxy Note 10.1
    Last Post: 08-31-2019, 06:41 PM
