1. Borgie's Avatar
    Note 10+ I am a little confused. The video you can set resolution, but there is no resolution setting for photos. I'm assuming this is controlled by the aspect ratio? I can't find any really good articles or youtubes on this.
    I took a picture with the standard camera (wide angle). Below is the resolution each aspect ratio gave. So by this, it shows 4:3 is the best aspect ratio to use for highest quality?
    Sorry if this question seems dumb, but I'm not a photography guru.
    Full aspect ratio 4032 x 1908
    1:1 Aspect ratio 3024 x 3024
    16:9 aspect ratio 4032 x 2268
    4:3 aspect ratio 4032 x 3024
    Full aspect ratio:
    Photo aspect ratio/resolution?  Confused as what setting to use-20190902_070609.jpg
    1:1 aspect ratio
    Photo aspect ratio/resolution?  Confused as what setting to use-20190902_070618.jpg
    16:9 aspect ratio
    Photo aspect ratio/resolution?  Confused as what setting to use-20190902_070627.jpg
    4:3 aspect ratio
    Photo aspect ratio/resolution?  Confused as what setting to use-20190902_070635.jpg
    09-02-2019 08:27 AM
  2. toenail_flicker's Avatar
    it's very much a personal choice but I will be using the highest quality which is the 4:3. I always handle any cropping myself.
    Borgie likes this.
    09-02-2019 08:31 AM
  3. srgonu's Avatar
    Usually I use 4:3 to maintain quality. But if am taking photos of nature, I prefer full or 16:9, so that I can use them as wall papers on my mac or note.
    Borgie likes this.
    09-02-2019 12:01 PM
  4. Gary02468's Avatar
    Correct. The sensor's ratio is 4:3, so anything else is just cropping the image and lowering the resolution. as you can confirm by multiplying each pair of pixel measurements for the various aspect ratios.
    Borgie and toenail_flicker like this.
    09-02-2019 12:10 PM
  5. toenail_flicker's Avatar
    use 4:3 and crop it yourself so you don't lose quality
    srgonu likes this.
    09-02-2019 03:09 PM
  6. Blaalad12's Avatar
    If your only going to be viewing your photos on the phone then just go with whatever you like best and dont worry to much about resolution! I use 16:9 and i personally am happy with the results!
    EMGSM likes this.
    09-02-2019 04:15 PM
  7. jrsharp70's Avatar
    I like 16:9 because I view my photos on my TV
    09-02-2019 04:23 PM
  8. Edson Cury's Avatar
    I just took 4 pictures and looking the details for each one I found the following:
    3:4 - 4032 x 1908 (results in 6 M)
    9:19 - 3024 x 3024 (results in 9 M)
    1:1 - 4032 x 2268 (results in 8 M)
    Full - 4032 x 3024 (results in 12 M)
    So, my results are very different from the ones mentioned by Borgle in his message:
    And in my case the highest resolution was in Full instead of 3:4 that you mentioned.
    What is correct?
    10-23-2019 10:27 AM
  9. toenail_flicker's Avatar
    What is correct?
    I'm going to assume you have the 10 and the other poster has the 10+ which would account for the difference, but I'm nobody here.
    10-23-2019 10:59 AM
  10. toenail_flicker's Avatar
    mine is different. for full I get the 11m, but my size is 4032 x 1908, and it all changes from there. I have the 10+
    10-23-2019 11:05 AM
  11. gernerttl's Avatar
    What is correct?
    You need to check your MATH.
    4032x1908 is the FULL setting
    4032x3024 is the 3:4 setting.
    Here are my results with the 12MP camera:
    3:4 3024x4032=12.1MP
    9:16 2268x4032=9.1MP
    1:1 3024x3024=9.1MP
    Full: 1908x4032=7.6MP
    Here are my results with the 16MP camera:
    3:4 3456x4608=15.9MP
    9:16 2592x4608=11.9MP
    1:1 3456x3456=11.9MP
    Full: 2184x4608=10.0MP
    The Note 10 and the Note 10+ both have the same cameras. The Note 10+ has an additional Time of Flight (ToF) camera which Samsung calls DepthVision camera with VGA resolution.
    10-23-2019 03:54 PM
  12. gernerttl's Avatar
    Reread those ratios.
    1:1 is NOT 4032x2268.
    The Note 10 and the Note 10+ have identical cameras. The ONE difference is the Note 10+ has fourth camera called a Time of Flight (ToF) camera which Samsung calls, "DepthVision" camera which is VGA resolution.
    10-23-2019 03:55 PM
  13. toenail_flicker's Avatar
    I'm assuming the rear camera here... not my results at all. I took photos, then reviewed the details and marked them as to each setting. here is my experience for the 10+. what phone do you have? is there another note 10 model?
    3:4 4032x3024 7.05 mb
    9:16 4032x2268 10.43 mb
    1:1 3024x3024 11.43 mb
    full 4032x1908 10.99 mb
    10-23-2019 04:52 PM
  14. toenail_flicker's Avatar
    I knew they were different. so why are we all getting different numbers?
    10-23-2019 04:53 PM
  15. gernerttl's Avatar
    Which camera setting did you use?
    The Photo setting has all three cameras available, the 12MP "normal" The 12MP "zoom" and the 16MP "ultrawide."
    Live Focus uses the 12MP "zoom" and 12MP "normal" cameras.
    Instagram uses the same cameras as Photo, but automatically defaults to the full setting. Food setting uses the 12MP "normal."
    I'm not sure how the Pro setting works, I believe it uses the 12MP "normal" camera.
    10-23-2019 05:01 PM
  16. toenail_flicker's Avatar
    this explains it. I'm using the standard shot. not ultra wide or ultra close.
    no one is comparing oranges to oranges.
    10-23-2019 05:02 PM
  17. gernerttl's Avatar
    Those are the 12MP camera, not the 16MP ultrawide.
    10-23-2019 05:03 PM
  18. gernerttl's Avatar
    That is because they are not paying attention to which camera setting they are using and actually comparing them. Plus...MATH.
    10-23-2019 05:04 PM
  19. toenail_flicker's Avatar
    right. that's what I said. the standard shot
    10-23-2019 05:05 PM
  20. toenail_flicker's Avatar
    Plus...MATH.
    rofl
    gernerttl likes this.
    10-23-2019 05:05 PM
  21. 7h3d34f0n3's Avatar
    Some maths make my head hurt.
    toenail_flicker likes this.
    10-23-2019 09:11 PM
  22. toenail_flicker's Avatar
    100%
    10-23-2019 09:15 PM
  1. Google Now Launcher, what replaced it?
    By mikeyg00 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-02-2019, 02:05 PM
  2. Switch to Mobile Data
    By osbourne one-nil in forum Samsung Galaxy Note 9
    Last Post: 09-02-2019, 01:25 PM
  3. Does your Note 10 or 10+ overly saturate/brighten your photos
    By Android Central Question in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-02-2019, 10:58 AM
  4. I cannot recognise missed call on call log as all numbers shown in black colour
    Last Post: 09-02-2019, 03:41 AM
  5. Recommended Tablet/eReader/Device for freelance/office/travel/personal use
    Last Post: 09-02-2019, 03:36 AM
