1. delta7's Avatar
    I'm looking at both and it seems the S10e just gets brighter and looks a little better. Even though both 1080p.
    I absolutely love the size of the small note 10 but this screen doesn't look to good.
    09-02-2019 02:34 PM
  2. mogelijk's Avatar
    From reviews I've seen, the Note 10 screen is brighter than the S10e, Tom's Guide has the S10e max brightness rated at 603 nits, and the Note 10s at 674 nits (the Note 10 Plus was measured at 686 nits).
    What it seems like you might not care for, the Note 10 (and Plus) have higher color accuracy -- using Tom's Guide again, they measured the color accuracy of the Note 10 at 0.25 and the S10e at 0.57 (lower numbers are better). My guess is that you like the "punchier" colors of the S10e screen -- and you can get a similar looking screen on the Note 10 by going into Settings>Display>Screen Mode and changing it from "Natural" to "Vivid."
    notefreak likes this.
    09-03-2019 08:10 AM
  1. how do you move the photos from the files to gallery
    Last Post: 09-02-2019, 09:55 PM
  2. I can't download pictures that are sent to me in a tex message
    Last Post: 09-02-2019, 09:54 PM
  3. Unlocked Galaxy Note 10+ Showing As Nubia Red Magic on AT&T
    By MCNPorter in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-02-2019, 06:33 PM
  4. I need to change my region / country in Google Play
    By cebrusak in forum Ask a Question
    Last Post: 09-02-2019, 03:04 PM
  5. I need to change my region / country in Google Play
    By cebrusak in forum Android Apps
    Last Post: 09-02-2019, 12:49 PM
