1. Misterb's Avatar
    Carrier video calling from the dial screen.
    I figured out how to get Verizon visual voicemail and also the Verizon caller ID for numbers that are not contacts/spam blocker.
    The only thing left is to figure out video calling. I realize I could use Skype or whatever, but is there a way to have the convenience of a Verizon version of the Note 10+ when it comes to video calling?
    09-04-2019 11:52 AM
  2. Fr0gburp3r's Avatar
    Doesn't it say to contact your service provider to enable that feature?
    09-04-2019 11:56 AM
  3. Misterb's Avatar
    Doesn't what say?
    09-04-2019 04:32 PM
  4. Fr0gburp3r's Avatar
    Doesn't what say?
    If you attempt to enable HD voice and video calling in Advance Calling settings.
    09-04-2019 07:48 PM
  5. Mike Dee's Avatar
    Even if it doesn't say it you usually have to enable on the carrier end.
    09-04-2019 08:16 PM
  6. Fr0gburp3r's Avatar
    Not sure why you would want it. Verizon offers it but the other person has to be on the same network as me for it to work. Just use one of the many apps in the Play Store for video calling that doesn't require both parties to be on the same network. I just use WhatsApp.
    09-04-2019 08:20 PM
  7. Misterb's Avatar
    I only used it in the past to video chat with the wife, who is on the same network with the same phone
    09-04-2019 11:54 PM
  8. Hghlndr's Avatar
    Verizon... gotta love'em! Consider Google's Duo.... easy enough. Good luck
    09-05-2019 01:49 AM
  9. Almeuit's Avatar
    You can't. That's Verizon software baked into the Verizon version. On an unlocked you can't do it.
    recDNA likes this.
    09-05-2019 07:44 AM
  10. Almeuit's Avatar
    I get hating Verizon is a thing but other carriers have the same thing.. that requires the same thing.. so .. yeah.
    09-05-2019 07:45 AM
  11. Almeuit's Avatar
    If you attempt to enable HD voice and video calling in Advance Calling settings.[IMG=485x1024]https://uploads.tapatalk-cdn.com/20190905/43df57ea17cb2db54f8c8d67dd269beb.jpg[/url]
    That's on a Verizon variant. He isn't on that.
    09-05-2019 07:48 AM
  12. chevyman29's Avatar
    Could you share with me how to get visual voicemail working on the unlocked model ?
    I found a good deal on a used 10e unlocked but couldn't get vvm to work so I backed out
    09-05-2019 11:02 PM
  13. Misterb's Avatar
    Have someone call your number and leave a voicemail. Once they do that, your phone should automatically set up Verizon visual voicemail. That's how mine worked
    09-05-2019 11:24 PM
  14. sulla1965's Avatar
    Verizon Visual voice mail isn't supported on unlocked phones.
    09-05-2019 11:43 PM
  15. Misterb's Avatar
    That's not true. Just because you can't see the app, doesn't mean it isn't supported. Like I said, have someone call your number and leave a message. At that point, the app will show up and you will be able to use it as always
    09-06-2019 07:34 AM
  16. LdotAdot13's Avatar
    I've got it on my unlocked Note 10. I'm on Verizon
    Attached Thumbnails My unlocked 10+ on Verizon now has all features, except...-35453.jpg
    09-06-2019 11:14 AM
  1. Android 10 on Essential phone
    By Roosterman in forum Essential Phone
    Last Post: 09-05-2019, 11:53 PM
  2. Is this SD card any good for the Note 10 plus - link in comment
    By Kath1404 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-04-2019, 01:14 PM
  3. Why do I have to hit down load when ever I get a text on s9+ ?
    Last Post: 09-04-2019, 11:36 AM
  4. Replies: 2
    Last Post: 09-04-2019, 11:15 AM
  5. Play Audio file on Google Home and Android Phone
    By Mancolt in forum Google Home
    Last Post: 09-04-2019, 10:41 AM
