1. jadenerd's Avatar
    This is probably a dumb question but will the wireless charger that I got as a freebie with the Note 7 charge at 25W if powered by the 25W charger? It's model EP-PG950.
    09-07-2019 10:58 AM
  2. Mike Dee's Avatar
    I don't understand your question
    09-07-2019 11:05 AM
  3. toenail_flicker's Avatar
    that is a good question. my older one works well enough, but I'm not sure if I can even swap my cord out for the other. might need an adapter. could be worth testing.
    jadenerd likes this.
    09-07-2019 11:06 AM
  4. hooligan03's Avatar
    what is the output of the charger? Amperage output x voltage output = wattage output
    09-07-2019 11:21 AM
  5. bhatech's Avatar
    I doubt it since along with the adapter the wireless charger also should support to handle that much power.
    toenail_flicker and jadenerd like this.
    09-07-2019 11:24 AM
  6. toenail_flicker's Avatar
    my TYLT is only 12v so the answer for me is no. need to look at the newer ones. it still charges very quickly though.
    09-07-2019 11:29 AM
  7. GDany's Avatar
    Agree! I wouldn't connect a more powerful adapter to a wireless charger which was not designed for that power. It will heat up and finally will get burned. But you could still use the wireless charger with its original adapter or similar in order to charge your Note 10/10+.
    09-07-2019 11:34 AM
  8. jadenerd's Avatar
    It only lists the input as 5.0V=2.0A and 9.0V=1.67A
    09-07-2019 11:44 AM
  9. jadenerd's Avatar
    If I plug the 25W charger that came with the phone into my current wireless charger would it charge the phone at 25W or is the output limited by the ability of the wireless charger. Hmmm - that sounds more confusing than my original question.
    09-07-2019 11:47 AM
  10. jadenerd's Avatar
    That makes sense. With that explanation it's a safety issue more than how fast the phone gets charged in the old wireless charger.
    Thanks, everyone, for clearing this up for me.
    toenail_flicker likes this.
    09-07-2019 11:49 AM
  11. felloffthetruck's Avatar
    No, the fastest wireless charge you can get is 15 watt and that's with the new wireless 2.0 chargers.
    j_hansen and jadenerd like this.
    09-07-2019 12:07 PM
  12. toenail_flicker's Avatar
    if I may, has anyone found a brand name qi wireless pad that charges at 12w (my TYLT Vu) or above? I need something for the bedroom and don't want a stand.
    09-07-2019 12:10 PM
  13. arunma's Avatar
    If you just search Amazon for "12W wireless charger" you'll find a few options. The Anker one is probably safe. Although at $30, that's getting to the point where you might as well buy a Samsung branded pad.
    But yeah, like you I also prefer a pad-style charger. The 15 W stand is pretty cool, but it would be even better if it were a pad.
    09-07-2019 12:34 PM
  14. toenail_flicker's Avatar
    tried that and the best I came up with the search was an Anker 10w *eye roll*
    yeah. I only want a pad because my night table is pretty wobbly and if I bumped it on a stand it would likely fall. I tend to thrash a bit in my sleep, covers etc., so I keep my phone resting on the pillow next to me while I stream and sleep. I wake up a lot and stream to go back to sleep so by morning it gets pretty low.
    09-07-2019 12:48 PM
  15. anon(10274434)'s Avatar
    I like the stand style - have both the Pixel and 10+ stands next to bed and with AOD I can see the time during the night - IMO the 10+ stand is a little more "solid"
    09-07-2019 12:49 PM
  16. toenail_flicker's Avatar
    insomniac here. if there is anything visual... little blue lights, clocks, anything at all... I can't go back to sleep and I wake on average 4-7 times a night depending. I have no clocks, duct tape on all bright as the sun blue green or red indicator lights on anything in my bedroom, and foam covering any blue lit displays (micro in kitchen and portable a/c unit). sleep for me is elusive and broken at best. and I tend to wake after four hours and can't go back to sleep. if I do, I will continue to wake up.
    09-07-2019 01:01 PM
  17. jadenerd's Avatar
    Completely off topic but I'm also an insomniac and have found the one thing that works for me - CBD oil. It took a couple of weeks of use and my sleep increased from a broken 2-3 hours a night to a solid 6 hours. I forgot to replenish my supply yesterday and I spent a completely sleepless night last night. Just something worth considering.
    09-07-2019 03:03 PM
  18. toenail_flicker's Avatar
    CBD oil
    thank you. tried it and same.
    09-07-2019 03:04 PM
  19. jadenerd's Avatar
    I've decided to use my old "fast charge" stand for night time charging and the 25 watt charger to finish the job in the morning. This gives me a dual solution.
    09-07-2019 03:06 PM
  20. j_hansen's Avatar
    I was going to suggest CBD oil as well, drops under the tongue works best for me
    09-07-2019 03:13 PM
  21. toenail_flicker's Avatar
    even sleeping pills don't work for me. what works best for a really bad night is diphenhydramine, but I still only get two hours sleep before I wake up. took Ambien and woke up after two hours. told the doc and he said take more... no thank you. too many side effects.
    09-07-2019 03:47 PM
  22. methodman89's Avatar
    Interesting. Careful what you mix it with
    09-07-2019 03:55 PM
  23. jadenerd's Avatar
    Same here
    09-07-2019 03:57 PM
  24. toenail_flicker's Avatar
    it was a sample, it was all I had, just a few of them, and I never asked for more. didn't work and I didn't do as he suggested. too many side effects. if you mean the benedryl, I only take a max of two during the night and never with anything else. I'm no fool.
    09-07-2019 05:00 PM
  25. methodman89's Avatar
    Never thought you were
    09-07-2019 05:05 PM
  1. Samsung Wireless Charger 10,000 Battery pack gets mighty hot
    By felloffthetruck in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-07-2019, 09:07 PM
  2. Fast Wireless 2.0 - 12W vs 15W
    By arunma in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-06-2019, 01:51 AM
  3. NO apps work each morning after taking phone off charger
    By budarooski in forum Samsung Galaxy S10 & S10+
    Last Post: 09-05-2019, 08:52 AM
  4. Where can I get a non-fake Note 4 fast charger?
    By isabel95 in forum Samsung Galaxy Note 4
    Last Post: 09-02-2019, 05:05 PM
  5. Verizon Note 10 Plus Wireless Charging in the Car
    By charlier180 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-02-2019, 01:22 PM
