1. DARK Vader777's Avatar
    Any updates or information as to when the Note 10 plus series will be able to get it?
    Don't know if this has already been asked.
    If so, point me in the right direction and delete if you may.
    Thank you.
    Goodlock was one of my favorites.
    09-07-2019 04:19 PM
  2. Vizi's Avatar
    Good Lock is available for N10+ in the Galaxy Store. I have it installed (Verizon).
    ROE_HUNTER and Alan Sims like this.
    09-07-2019 04:27 PM
  3. KruseLudsMobile's Avatar
    Thank you.
    Yes, you install it and then run it, then in the app itself you can select the other modules to install. Works like a charm.
    09-07-2019 05:48 PM
  4. Xxwabbit's Avatar
    I used it yesterday, to try it out and change the clock placement. But all the other icons disappeared. Not sure what to do about that. What other fun stuff can you do?
    09-07-2019 09:00 PM
  5. Hermes Hidayat's Avatar
    Thank you.
    Im on unlocked. And Goodlock works well.
    09-07-2019 09:34 PM
  6. hooligan03's Avatar
    You have to add the icons back in to be visible when you enable good lock. It blanks it out like starting at ground zero when you turn on GL.
    Xxwabbit, ROE_HUNTER and Bkdodger1 like this.
    09-07-2019 09:37 PM
  7. wdfrancis58's Avatar
    How do you do that? I've installed good lock and then uninstalled it. I'm missing several icons.
    09-07-2019 09:47 PM
  8. KruseLudsMobile's Avatar
    Launch the good lock app. When you do so, you will see options - inside the app - for installing many other objects with additional functionality.
    09-07-2019 09:57 PM
  9. KruseLudsMobile's Avatar
    09-07-2019 09:57 PM
  10. wdfrancis58's Avatar
    Nevermind. I figured it out.
    09-07-2019 10:07 PM
  11. DARK Vader777's Avatar
    Yes, I remember about a week ago trying to install this and wasn't about to.
    Thanks, everything is a go.
    Maybe it was a Sprint thing who knows.
    The thing is, Samsung has one good thing from the store that most of us like and use.
    I'd like to keep using it.
    09-08-2019 12:11 AM
  12. Jaskaran Bhatia7's Avatar
    Bro you need to download it from galaxy store , it's there.
    09-08-2019 01:04 AM
  13. Blaalad12's Avatar
    Is good lock only available in certain regions? I the unlocked european model and good lock is not in the galaxy store nor was it available on my previous device either
    09-08-2019 08:50 AM
  14. mustang7757's Avatar
    I believe so
    09-08-2019 08:51 AM
  15. Bkdodger1's Avatar
    Use Nicelock ...I’m in US but I use Nicelock and update the modules with apk downloads ..
    09-08-2019 09:15 AM
  16. Blaalad12's Avatar
    I dont understand Nice lock? It has ads and is useless without the apk modules. Makes more sense to just download a vpn and install good lock! There both virtually the same thing
    09-08-2019 11:11 AM
  17. Bkdodger1's Avatar
    I don't use VPN but that's always a choice... NiceLock works for me no issues... It's just one that I've always used so it downloads when I restore my apps .. it's either you get modules from store or apks... Differencs
    09-08-2019 11:25 AM
  1. Anyone trying the EMUI 10 beta?
    By Mikey88Chaos in forum Huawei P30 & P30 Pro
    Last Post: 09-17-2019, 03:43 PM
  2. Enabling Call & Text On Other Devices won't turn on with the Note 10+
    By mxrider821 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-09-2019, 11:09 PM
  3. Technical Question and Reference - Wireless 10,000 mAh Charging Battery
    By KruseLudsMobile in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-09-2019, 10:06 PM
  4. Replies: 9
    Last Post: 09-09-2019, 09:39 PM
  5. Updated to 10 now google account does not work cannot sign in or out
    Last Post: 09-07-2019, 04:47 PM
