1. Maka08's Avatar
    Hey all, I'm currently on the first week using my note 10+ and I'm concerned about my battery life. After a full charged, 8 minutes in idle after I unplugged the battery dropped 1% . I turned on Bluetooth as I hoped into my car to go to work and it dropped another 1%. So within 10 minutes from unplug I have lost 2% for doing nothing to the phone. Just wondering if this is normal? FYI the phone lasted on around 5 hours screen time from the last few cycle. Screen on wqhd and adaptive brightness. Optimised battery setting and apps.
    09-08-2019 11:00 PM
  2. mustang7757's Avatar
    It will get better as it learns your usage
    09-08-2019 11:05 PM
  3. iGalione's Avatar
    are you using any wifi or any other networks? if you're using just cellular and no wifi, that does put strain on the battery and you tend to use more battery with just the bare cellular network, ESPECIALLY if you happen to be in a weak/low signal area.
    But as mustang stated, your connectivity and battery will adapt after much days of usage.
    09-09-2019 09:47 PM
  4. Maka08's Avatar
    Well most of my day my phone will be on wifi as my work has wifi and going to work is only half an hour so hardly any time for cellular. I've noticed that my screen is draining the most %. It's draining at least 20% while other things are not even breaking double digits. Im awarded that I have wqhd on but that's about it. Maybe I'll run the device on fhd for the day and see the difference.
    09-10-2019 09:57 AM
  1. Watch to go with new Note 10
    By 2015Mustangturbo in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-26-2019, 10:17 AM
  2. Google Assistant and Android 10
    By pauldroidr2d2 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 09-27-2019, 10:40 PM
  3. Does anyone know of a vr headset that is compatiable with the note 10 plus,many thanks
    By Android Central Question in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-13-2019, 11:04 PM
  4. Note 10 in aura pink on Overstock
    By Shelacios in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-09-2019, 02:17 PM
  5. Anyone else having trouble or very poor connection with s10plus or note?
    Last Post: 09-08-2019, 06:40 PM
