08-13-2020 04:38 AM
338 123 ...
tools
  1. mustang7757's Avatar
    Ok I'll start this off , see if it can be a sticky and Ruben will update files as they come out .
    September security patch file :
    https://androidfilehost.com/?fid=1899786940962581515
    Guide on recovery mode or download mode
    09-10-2019 11:19 AM
  2. msm0511's Avatar
    Thanks buddy!
    mustang7757 likes this.
    09-10-2019 11:20 AM
  3. mustang7757's Avatar
    No problem
    Thanks buddy!
    msm0511 likes this.
    09-10-2019 11:40 AM
  4. mustang7757's Avatar
    09-10-2019 12:03 PM
  5. Ruben Ocasio's Avatar
    Thanks
    09-10-2019 12:36 PM
  6. Ruben Ocasio's Avatar
    Aug and September Odin all will be in this link: https://androidfilehost.com/?w=files...&sort_dir=DESC
    09-10-2019 12:40 PM
  7. Ruben Ocasio's Avatar
    So basically anytime i upload Odin files they will be all at that link.
    09-10-2019 12:46 PM
  8. Ruben Ocasio's Avatar
    Can You Please Post This Link In OPS First Post That way it's alway in first post and easier to find https://androidfilehost.com/?w=files...&sort_dir=DESC
    09-10-2019 03:32 PM
  9. mustang7757's Avatar
    Who's post ?
    09-10-2019 03:48 PM
  10. Ruben Ocasio's Avatar
    Who's post ?
    You Open thread so put it in your first post. That's how we do on XDA put link in the first post of this thread, and easier to find instead of looking thru the thread for links.
    09-10-2019 04:03 PM
  11. bhatech's Avatar
    Who's post ?
    He means to put the Android file host link he gave in your OP or first post. So that's it's easier for everyone to find.
    09-10-2019 04:04 PM
  12. mustang7757's Avatar
    Gotcha, will do
    Thanks
    09-10-2019 04:09 PM
  13. Flytetymex's Avatar
    Has anyone actually been successful installing this update with Odin on the note 10+? Coming from a Pixel3XL and I'm aware I'll rarely get updates so was interested in trying it out. SM-N975U1 here.
    09-10-2019 04:52 PM
  14. mustang7757's Avatar
    This is the carrier version, not the unlocked
    09-10-2019 05:09 PM
  15. Flytetymex's Avatar
    Gotcha. Thank you sir. But out of curiosity, has anyone been successful in doing the carrier update on this phone with Odin?
    09-10-2019 05:21 PM
  16. Ruben Ocasio's Avatar
    Yes few on XDA has Odin with this link i provided and no one has had no issues, AT&T, Verizon, T-Mobile and Sprint all have had success on this.
    09-10-2019 05:38 PM
  17. nuangel2's Avatar
    when I click on these links page is empty
    09-10-2019 07:07 PM
  18. Flytetymex's Avatar
    Thanks man
    09-10-2019 08:01 PM
  19. mustang7757's Avatar
    Really, how are you accessing AC?
    09-10-2019 08:14 PM
  20. sweetypie31's Avatar
    I'm still on July. Do I have to Odin to Aug before I do Sept or can I skip Aug?
    09-10-2019 08:22 PM
  21. mustang7757's Avatar
    You can skip
    sweetypie31 likes this.
    09-10-2019 08:52 PM
  22. nuangel2's Avatar
    On a windows 10 PC
    09-10-2019 08:54 PM
  23. sweetypie31's Avatar
    Update done. Thanks guys.
    09-11-2019 12:44 AM
  24. Ruben Ocasio's Avatar
    Let Everyone Know What Exactly You Did that way it can help others flash it the right way , and which tar files you put in odin, i mean i'm pretty sure i know how you did it, but always good for someone else to tell us how you did it and worked with no issues Thanks!
    nuangel2 likes this.
    09-11-2019 12:55 AM
  25. james702283's Avatar
    Is there any advantage to do this as opposed to just updating normally?
    09-11-2019 02:16 AM
338 123 ...
  1. P40 Pro Banking Apps vs Web versions?
    By OnkenEater313 in forum Huawei P40
    Last Post: 06-30-2020, 07:38 AM
  2. Wi-Fi Calling with unlocked Galaxy S20 on AT&T?
    By Bzguy2148 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 06-15-2020, 07:24 PM
