1. elkido122's Avatar
    I need a nice charge cable to replace the stock one thays to short. Itll be used on the stock charge adapter . I see some that are usb c 2.0 and some that are usb c 3.1. Anyways can someone reccomend a good cable for this phone. Thanks
    09-10-2019 06:15 PM
  2. anon(7901790)'s Avatar
    This should clear it up a bit.
    https://www.trustedreviews.com/opini...o-know-2932202
    There is no such thing as "USB-C 2.0." USB-C already includes USB 3.1.
    USB-C is the physical connector.
    Serkle K likes this.
    09-10-2019 07:23 PM
  3. Davenurse's Avatar
    Anker [2-Pack] 3ft / 0.9m Nylon Braided Tangle-Free Micro USB Cable with Gold-Plated Connectors for Android, Samsung, HTC, Nokia, Sony and More (Red) https://www.amazon.com/dp/B07BRQSN5C...cUvbUpU6638907
    Bought these great replacement for stock cable. Great price and they are fabric covered cables
    09-10-2019 08:49 PM
  4. elkido122's Avatar
    ^^^^ Thanks but that's not usb c for the note 10. Anyone else with a cable recommendation
    09-11-2019 03:41 AM
  5. MysticalDreams's Avatar
    If you are wanting fast charging you won't get it with a 3rd party cable. At least that is my experience with Samsung
    09-11-2019 04:11 AM
  6. james702283's Avatar
    That's not true. I have found 2 different cable brands, one for 6ft and one for 10ft that both charge from the stock 25w charger at the same exact speed as the short stock cable that comes with it.
    The 6ft one is sold out on amazon so I attached an image.
    10ft is here: 60W/5.0A 10ft USB Type C to USB C Cable, CABEPOW 2Pack USB-C to USB-A 2in1 Fast Charger Cable Compatible for Samsung Galaxy Note 8 S8 S8+ S9, Google Pixel,Nexus 6P,Matebook, MacBook,iPad Pro Case 2018 https://www.amazon.com/dp/B07MBG6772...cUvbUpU6639175
    09-11-2019 04:25 AM
  7. elkido122's Avatar
    What about anker powerline or powerline 2 cables. Can they fast charge??
    09-11-2019 09:56 AM
  8. Serkle K's Avatar
    I got this one and it works fine with the OEM charger brick. Same charging time as the original cable. But it's not as long as the OEM cable. I think they do make a 6ft one though, and it should have a more flexible braided cable.
    In any case, I started a thread about the proper cables to use, and in short, you want it to be USB-C on both ends, or a USB-C to USB 3.1 Gen2 connector to take advantage of the proper charging speeds.
    09-11-2019 10:40 AM
  9. Vizi's Avatar
    I went with this one. Note10+ I need a charge cable help me choose-smartselect_20190911-125648_amazon-20shopping.jpeg
    EMGSM and nonie like this.
    09-11-2019 11:57 AM
  10. EMGSM's Avatar
    I went with this one. Click image for larger version.
    I got the same one.
    09-11-2019 03:09 PM
  11. toenail_flicker's Avatar
    09-11-2019 03:21 PM
  1. my phone keeps calling me and it pops up the "voicemail" calling. Why?
    Last Post: 09-13-2019, 03:41 AM
  2. Samsung A10 incoming calls are shown as "unkwown" please help
    Last Post: 09-10-2019, 11:44 PM
  3. Wireless charging?
    By nonie in forum Samsung Galaxy S8 & S8+
    Last Post: 09-10-2019, 02:42 PM
  4. Question for iPhone users who switched to Note10+
    By algiii in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-10-2019, 02:39 PM
  5. how do i delete the me contact from my android
    Last Post: 09-10-2019, 08:09 AM
