1. cache11's Avatar
    I wonder why the regular Note 10 has a toggle to turn fast wireless charging on and off and the Note 10+ does not?
    09-10-2019 07:22 PM
  2. Katrina White1's Avatar
    It does. Go to battery settings
    09-10-2019 07:41 PM
  3. Katrina White1's Avatar
    3 dots
    09-10-2019 07:43 PM
  4. msm0511's Avatar
    Could also be one of those things a pesky carrier removed.
    09-10-2019 07:44 PM
  5. Katrina White1's Avatar
    Ohhhh...True. Didn't think of that.
    09-10-2019 07:46 PM
  6. Mike Dee's Avatar
    Have you actually connected it to a fast wireless charger?
    It doesn't appear unless you do.
    09-10-2019 08:38 PM
  7. Mike Dee's Avatar
    I sort of doubt it.... It's possible the OP hasn't connected it to a fast wireless charger which triggers that toggle to appear.
    09-10-2019 08:39 PM
  8. trucksmoveamerica#AC's Avatar
    I wish they would put a toggle in the drop down notification box to turn fast charging on or off.
    Serkle K likes this.
    09-10-2019 09:11 PM
  9. Mike Dee's Avatar
    Would you actually use it often?
    09-10-2019 10:06 PM
  10. trucksmoveamerica#AC's Avatar
    I would. I don't have fast wireless charging turned on. Most the time I'm wireless charging over night so no need for it, but occasionally I need to do it other times and it would be nice to have a quick way to turn it on or off as needed, it's kind of a pain the way it is now.
    09-11-2019 03:33 AM
  11. Rukbat's Avatar
    Fast charging doesn't shorten the battery life or cause any other problems, so there's really no need to turn it off. If the phone is sitting on the charger all night, it will charge to 100%, stop charging and, if during the night it drains down past the trigger point (probably around 97% or 98%) it will top off again, the same as with regular charging. (Fast charging stops at around 70% anyway, then you're back to normal charging, so the battery doesn't overheat.)
    09-11-2019 05:14 PM
  12. trucksmoveamerica#AC's Avatar
    I know that's what I hear all the time, but I'm old school yet, lol. I always hear heat is bad for batteries and fast charging usually causes more heat so I just don't use it since it's all night charging and there's no hurry. I suppose I should just change my old school thinking. Lol
    09-11-2019 06:49 PM
  13. just_luc's Avatar
    If that was true why would Samsung turn it off by default and why give the option to turn it on and off at all?
    09-12-2019 07:31 AM
  14. msm0511's Avatar
    Samsung doesn't turn it off by default.
    09-12-2019 08:16 AM
  15. trucksmoveamerica#AC's Avatar
    Wireless fast charging option to turn on or off does not appear in options until you connect it to a fast wireless charger.
    09-12-2019 08:19 AM
  16. Mike Dee's Avatar
    It doesn't appear till you connect a wireless fast charger
    09-12-2019 01:09 PM
  17. mustang7757's Avatar
    09-12-2019 01:12 PM
  18. msm0511's Avatar
    Weird. I don't remember mine doing that. But I trust you guys.
    toenail_flicker likes this.
    09-12-2019 01:57 PM
  1. Galaxy Watch, No Notification Alert
    By zebra23 in forum Samsung Galaxy Watch
    Last Post: 09-18-2019, 07:04 AM
  2. Storage keeps filling up even though no new apps or files added
    Last Post: 09-13-2019, 12:37 AM
  3. Note10+ I need a charge cable help me choose
    By elkido122 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-11-2019, 04:21 PM
  4. How do I turn off capslock on my asus chromebook?
    Last Post: 09-11-2019, 12:10 AM
