Just got my Note 10+ and it came with last year's fast wireless charging pad with fan at 9w free
I only wireless charge at night but would it be worth getting the new 15w one for $80? Which are you using?
I'm using this one. 15w from Samsung.
Im currently using Anker 10W Wireless charger.
I am using the one I got with my Note 8.
I bought that one and can't use it. it charges, I think, but it caused so much vibration and rattling from the speaker that I'm returning it. unusable if you want to listen while charging.
owh...i havent tried that.but ill try when im home.i also use Spigen F306W.but i dont always use it as it causes static...
If you only use it for overnight charging, like I do, then you would be better saving your money and wait. No need for a faster charger unless you want it for work where you may not have as time to wait to charge.
Plus the wireless charger will likely go only sale or be discounted over time as newer models get released.
What's the time to full charge from 20 or 25%?I'm using this one. 15w from Samsung.
with your 15w, What's the time to full charge from 20 or 25%?The new samsung 15w and the 2018 charge pad.![]()
That's exactly what kept me from buying it yesterday as I held it in my hands at best buy ready to blow $80 lolI have a 10w one. If you only use it at night, I'd just stick with what's free for now. If down the line you decide you need something faster you can buy then.
