1. Casey Cheung's Avatar
    I am very pleasantly surprised to find out that the supplied Note 10+ charging cord/brick is able to charge my 10" Microsoft Surface Go Windows laptop (that also takes USB-C charging). The laptop normally takes a 24 watt charger, but the lower powered Samsung Note 10+ charger works fine in charging my laptop even while I'm using the laptop for doing stuff. My previous Samsung S9 charger wasn't able to do this. Now I don't need to buy an extra Microsoft OEM laptop charger for $40. Yay!
    Apple2Droid likes this.
    09-12-2019 01:52 PM
  2. j_hansen's Avatar
    your Note 10 charger is 25w
    09-12-2019 02:19 PM
  3. Casey Cheung's Avatar
    Wow, if that's true, that's great! But I'm curious, I can't find that info on all the small print on the brick. Lots of numbers, but nothing that specifically says wattage info.
    09-12-2019 03:10 PM
  4. anon(7901790)'s Avatar
    You have to do some math.
    W=VxA
    9Vx2.77A=24.93W. Or rounded off 25W
    Or
    You can just read the specs here :
    https://www.chargerlab.com/samsungs-...-afc-hello-pd/
    09-12-2019 03:40 PM
  5. icnmayhem's Avatar
    I envy you. my spectre needs a 65w charger. so the note charger wont charge it fast enough, and the 65w spectre charger only charges the note at 15w.
    09-12-2019 03:47 PM
  6. Casey Cheung's Avatar
    Aaahh, good ol' math! Thank you very much! Excellent usage of your stylus pen there too, I might add! Makes me wanna pull out my own now, haha!
    09-12-2019 04:57 PM
  7. Casey Cheung's Avatar
    I specifically purchased the Microsoft Surface Go laptop knowing that it takes USB-C charging, which makes it easier to charge versus the old dark ages of using proprietary bricks by the manufacturers. Heck, I can even charge my Surface Go laptop using a 12 volt car charger. Even my other laptop, a new Lenovo Thinkpad 2-1 hybrid also takes USB-C charging, but alas that requires more wattage. My goal is to standardize my charging cords so as not to have so many different types. So for now, my Microsoft Surface Go laptop, Lenovo Thinkpad laptop, Note 10+ phone all take USB-C for charging. Not so coincidentally, all 3 of those devices also have a stylus pen for writing too. I also use micro-USB because I have many older devices that require this for charging such as my earphones, bluetooth speakers, and older tablets, etc. My Garmin GPS devices take a mini-USB...grrr!
    09-12-2019 05:07 PM
  1. Sir why my game is stop runing in my Samsung A3 phn??
    Last Post: 09-13-2019, 03:00 AM
  2. My G Flex 2 won't charge or turn on
    Last Post: 09-13-2019, 12:45 AM
  3. How can I change the default duration of calendar events?
    Last Post: 09-12-2019, 03:52 PM
  4. Found Official Samsung Galaxy Note 10+ Clear Case on Mobile Fun
    By YaniCruz in forum Samsung Galaxy Note 10 & Note 10+ Cases & Accessories
    Last Post: 09-12-2019, 03:16 PM
  5. Can I use different unlocks?
    By 000jesus in forum General Help and How To
    Last Post: 09-12-2019, 02:44 PM
