1. arunma's Avatar
    Has anyone experienced the following?
    I've got the Note 10+. Every so often (about 2-3 times per hour), I hear a notification sound, but there is no actual notification. I've also checked for records of notifications via the settings menu, as well as "Nice Catch" on Good Lock. I'm unable to identify the source of these notification sounds.
    It's a minor issue, but would be very good to be able to fix this. Any input would be appreciated, thanks!
    09-12-2019 10:29 PM
  2. Javier P's Avatar
    Do you have NFC enabled?
    09-12-2019 10:33 PM
  3. mustang7757's Avatar
    Double check your web browser , any tabs open giving a notification
    09-12-2019 10:54 PM
  4. jtcannonball's Avatar
    Curious as well. My wife said to me she loves her phone but it just "sings" to her randomly all day, but no notification to show what it is. n
    Hermes Hidayat likes this.
    09-12-2019 10:55 PM
  5. Hermes Hidayat's Avatar
    is your phone on Silent or not?
    09-12-2019 10:59 PM
  6. B. Diddy's Avatar
    I agree with Javier P, the first thing to check is if it goes away when NFC is off. If you have a wallet-style case with credit cards or other cards with an NFC chip, the phone may detect them and give you the NFC tone.
    09-13-2019 01:00 AM
  7. Ruben Ocasio's Avatar
    Is the Spen in the phone?
    09-13-2019 01:14 AM
  8. CKwik240's Avatar
    Bixby routines makes notification sounds when something is triggered. I hear it all the time as I'm getting to or leaving work as I have it set by location
    09-13-2019 02:19 AM
  9. Vizi's Avatar
    I think something is up with the s-pen. I first noticed it when using Google maps and the map would minimize out of nowhere. Then the same thing started happening with YouTube. This would only happen in landscape. There would be a slight vibration and notification. Nice Catch says it's the S-Pen. I hope it's not a hardware problem.
    09-13-2019 06:35 AM
  10. arunma's Avatar
    I do. But this will happen even when the phone is sitting on a table with no NFC devices around.
    09-13-2019 11:58 AM
  11. arunma's Avatar
    Yup, it's in the phone.
    Last night I tried clearing the cache partitions. Let's see if that fixes the issue.
    09-13-2019 11:59 AM
  12. arunma's Avatar
    I found an almost embarassingly simple solution:
    Settings -> Accessibility -> Advanced Settings -> Notification Reminders -> Turn Off
    Apparently this is a setting which will (by default) sound the notification chime every 3 minutes when there is an unaddressed notification. So that's 20 times per hour, as opposed to the 3 I was noticing.
    I have no idea why anyone would want this. But if you're hearing notifications randomly, this is why it is happening and how you can turn it off.
    09-14-2019 12:00 AM
  13. mustang7757's Avatar
    Glad you found it ..
    arunma likes this.
    09-14-2019 12:17 AM
  14. Shelacios's Avatar
    Thanks Arunma. I had deducted it was related to unviewed notifications, but was too lazy to research how to fix it.
    arunma likes this.
    09-14-2019 02:04 AM
  15. arunma's Avatar
    Oh I was lazy too. But this thing was driving me crazy by prompting me to pick up my phone every few minutes for no reason. Madness is a good motivator.
    toenail_flicker likes this.
    09-14-2019 08:41 AM
  16. vja4Him's Avatar
    My Note 10 Plus just started "Beeping" every 30 seconds or so, four beeps. Very annoying. I cannot turn the sound off, as I am on call for work and must listen 24/7 for job assignments. I went through every application and turned off all notifications except for two apps > Phone and > Jobulator. I cannot turn off the notifications for the System apps though. I checked everything. S-Pen is inside the phone correctly. NFC off. There are no Notifications at all, just this annoying "Beeping" several times every minute.
    When I restarted my Note 10 Plus, it's back to normal now !!! Hopefully just a temporary glitch.
    10-26-2019 11:05 PM
  1. What antivirus apps you using for your Note 10+ ?
    By Casey Cheung in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-18-2019, 06:26 AM
  2. Hoogle pixel 3a screen randomly gors dark and unresponsive to touch
    Last Post: 09-13-2019, 12:14 AM
  3. Replies: 2
    Last Post: 09-12-2019, 10:17 PM
  4. Android showing full conversation in text message notification
    By Buttaz54 in forum Samsung Galaxy S8 & S8+
    Last Post: 09-12-2019, 10:15 PM
  5. Bixby turning on while locked.
    Last Post: 09-12-2019, 08:22 PM
