1. stewarta13wsb's Avatar
    Tried unpairing, updated Samsung Music Player, but still have a random issue (and on two different cars) a few tracks will play fine and then the next fails and you get a horrible loud jumbled electronic noise. Hit next track and usually it will then play fine, although occasionally not.
    Edit/Update - just tried my Aukey speaker and it's the same, so not BT!
    Player or corrupt tracks?
    09-14-2019 02:50 PM
  2. o4liberty's Avatar
    Sounds very weird I was having issues with a aftermarket kenwood car stereo doing what you describe I took it to best buy who installed it and they reset the radio and all is good now.
    09-14-2019 03:09 PM
  1. The Android app problem
    By RaRa85 in forum Android Apps
    Last Post: 09-21-2019, 03:44 AM
  2. voice calls over bluetooth issue
    Last Post: 09-14-2019, 01:37 AM
  3. Google Photos App Problem After Android 10
    By Fisher99 in forum Android 10
    Last Post: 09-12-2019, 04:21 PM
  4. my problem is the gallery app.
    Last Post: 09-12-2019, 03:53 PM
  5. "Bluetooth keeps stopping" after update android 9.0 on samsung J3pro
    By Youssef18 in forum Samsung Galaxy J Series
    Last Post: 09-10-2019, 10:47 AM
