1. felloffthetruck's Avatar
    My Note 10+ will drop from 100% to 99% within like 1 minute after removing from the charger.
    Is this normal?
    09-14-2019 04:05 PM
  2. mjs2011's Avatar
    Yes. It's actually accurate unlike iPhones that keep it at 100% for a half hour.
    thorstedswife likes this.
    09-14-2019 04:10 PM
  3. toenail_flicker's Avatar
    Is this normal?
    all I know is mine does the same thing and it freaks me out. I don't remember my Note 8 ever doing that.
    09-14-2019 04:14 PM
  4. msm0511's Avatar
    Is this normal?
    As long as it lasts me all day I don't worry about the actual percentage as much. But yeah, it goes to 99 super fast.
    queenren likes this.
    09-14-2019 04:16 PM
  5. KupKrazy's Avatar
    Every single Android phone that I have had does that after you install a few apps. Theoretically, it can't be 100% very long after you unplug it. Think about it, even if you say that the measurement rounds up and down based on actual measurement - it can only be at 100% when the actual capacity is 99.5-100%. You can't have capacity of over 100%. Compare that to the range of 99% which would show when the actual capacity is 98.5-99.4%. That is double the range to show. So theoretically, it can only stay at 100% less than half the time it would stay at 99%. Of course this depends on what apps you have running, etc.
    09-14-2019 04:29 PM
  6. smooches680's Avatar
    Yes mine does that as well and was wondering the same thing.
    09-14-2019 04:38 PM
  7. rabernet's Avatar
    I don't even pay attention to that. I'm of the camp that I'm more worried about all day than the 100 to 99 marker.
    adegbenroagoro likes this.
    09-14-2019 04:47 PM
  8. mach1man's Avatar
    Mine does the same, that's why I'm happy I dont have to have the battery % visible all the time. If I wanna see where I'm at I'll just slide the notification panel down and check.
    09-14-2019 04:53 PM
  9. Relletti's Avatar
    Mine does this. Its annoying but whatever. My note 8 did the same thing.
    09-14-2019 05:50 PM
  10. kj11's Avatar
    I mean, it does go from 100-99 pretty fast, but then it takes forever to go from 99-0, so I'm not really concerned about it
    Alan Sims likes this.
    09-14-2019 06:33 PM
  11. NIZMOZ44's Avatar
    The way Samsung has their phones programmed is when it's charging and hits 100%, it then allows it to drain a little then trickle back up to 100 again during the night while it's on the charger. So sometimes you may catch it when its at the low part of the drain before it trickles it back up and your phone will drop rather quickly to 97% or so. If you need that extra bit, I usually grab it off my charger then place it back on in the morning, take a shower, then the phone is really at 100% when I get it and won't drain that quick.
    09-14-2019 07:15 PM
  12. Roustermiller's Avatar
    Really thought something was wrong with my phone lol but I can say the battery life is amazing
    09-14-2019 07:44 PM
  13. Morty2264's Avatar
    Do what I do - turn off your battery percentage indicator and don't worry about it! I'm sure all is good.
    09-14-2019 08:02 PM
  14. 11B1P's Avatar
    It's like laundry. You're never caught up on clean laundry, because even when you've washed everything, you still have the clothes you're wearing.....unless you walk around the house naked.
    09-14-2019 08:51 PM
  15. mustang7757's Avatar
    Every Android phone I had did this, nothing new.
    NIZMOZ44 likes this.
    09-14-2019 08:53 PM
  16. bandofbrothers2112's Avatar
    The best tip I received years ago was to turn Off the battery % sign in the status bar and just enjoy what the phone brings.
    strikeIII and Relletti like this.
    09-15-2019 03:10 AM
  17. me just saying's Avatar
    nothing to be concerned about. Never rely on percentage anyway. one post mentioned the iphone keeping 100 percent for 30 minutes. aint no way, IMO, the apple phone is lying.
    09-15-2019 03:55 AM
  18. Ruben Ocasio's Avatar
    That's not real , if it does that then Apple is fooling people.
    09-15-2019 06:24 AM
  19. Bkdodger1's Avatar
    Most definitely... My iPhone stays on 100% for the longest when not using ...
    09-15-2019 08:38 AM
  20. j_hansen's Avatar
    Is this normal?
    Yes normal, my Notes always went down fairly quick on the first 5-10% nothing to worry about
    09-15-2019 09:11 AM
  21. bassplayrguy's Avatar
    As soon as you unplug your phone from the charger it is at 99%. 100% is fully charged so powering your phone for even a second takes power from the battery making it less than 100%.
    09-15-2019 09:19 AM
  22. strikeIII's Avatar
    I started doing this too. I'm always topping up through out the day anyway so the percentage is not even needed. In haven't had a device including the Note 10+ that can last me the whole day. I use my device a lot and have a lot of email accounts setup.
    Relletti likes this.
    09-15-2019 09:20 AM
  1. Gear4 Battersea - One Fine Note 10 Plus Case.
    By felloffthetruck in forum Samsung Galaxy Note 10 & Note 10+ Cases & Accessories
    Last Post: 09-18-2019, 11:20 AM
  2. How to associate an app with a file type.
    Last Post: 09-14-2019, 05:52 PM
  3. Android 10 Roaming Issue
    By dawgatron in forum Android 10
    Last Post: 09-14-2019, 05:35 PM
  4. How to associate an app with a file type.
    Last Post: 09-14-2019, 05:33 PM
  5. How to associate an app with a file type.
    By AnnetteElmore in forum Samsung Galaxy Tab 10-inch
    Last Post: 09-14-2019, 03:25 PM
