1. onthehunt's Avatar
    Came from the Note 8, which has great call volume through the internal earpiece and speakerphone and excellent volume with audio playback from other apps. The 10+ speakerphone volume is noticeably not as loud as my Note 8, and the extra volume function icon is missing on the call screen. Also, a handful of apps have lower volume with audio playback. Anyone else experiencing this?
    09-15-2019 02:20 AM
  2. Glorytech's Avatar
    This may be due to your sound settings, Go to Accessibility > Hearing > Mono Audio > Set it to off
    If the problem isn't this try going to Settings > Sounds and Vibrations > Sound Quality and Effects > Set equilizer to Nornal
    If none of this works It may just be the phone speakers dogy or thats how all s10+ are
    09-15-2019 02:26 AM
  3. Ruben Ocasio's Avatar
    You might have something set wrong cause i have my Note9 here, my daughter has the Note8 i compared them next to my Note10 Plus and it out blasted the Note9 and Note8 sound.
    09-15-2019 09:04 PM
  4. tivoboy's Avatar
    Is there any way to actually test the earpiece on the note 10+. When I am on a call using the phone, getting the sound from the TOP of the phone most likely it seems VERY hard to hear the other party
    10-04-2019 10:51 AM
  1. Replies: 17
    Last Post: 09-29-2019, 04:14 AM
  2. Single Tap Mode to Answer Call on Note 10+
    By onthehunt in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-16-2019, 05:45 PM
  3. Mi 9t. Max settings heavy gaming on Snapdragon 730 question?
    Last Post: 09-15-2019, 03:10 AM
  4. Replies: 3
    Last Post: 09-15-2019, 02:40 AM
  5. Mobile Data Turned off Notification on Note 10 plus
    Last Post: 09-15-2019, 12:43 AM
