    I have blue light filter and night mode off. Is there something that would only make certain application have yellow tint? Tinting is not present on homescreen, messages and a couple other applications. Anyone have ideas on what could cause this?
    09-17-2019 01:34 AM
  2. mustang7757's Avatar
    Hi, welcome to Android Forums
    I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
    I'll provide a link to register, please come back to your post so we can further assist you . Thank you
    https://forums.androidcentral.com/sh...d.php?t=409154
    09-17-2019 08:29 AM
  3. mustang7757's Avatar
    From you telling me only certain application , I think it's from that application, which is it by the way?
    09-17-2019 08:30 AM
  4. Asburner's Avatar
    Gallery and pokemon go are the two I noticed it in so far. It's not turned on at the homescreen, chrome or messages. But it also only turns on when its night time.
    09-17-2019 02:23 PM
  5. mustang7757's Avatar
    Hi, welcome
    Strange , you using a launcher?
    09-17-2019 02:41 PM
  6. Asburner's Avatar
    Just got the phone, so the default, one UI home
    09-17-2019 02:46 PM
  7. realaace's Avatar
    I had this problem with Gallery and Google Photos and it was driving me nuts! Finally found the solution. There is a hidden night mode in Google Play Books. Open any book, tap the Aa on the upper right. Go into night light settings, tap Schedule and turn it off completely.
    09-18-2019 09:18 AM
  8. mustang7757's Avatar
    I think your right , I do remember now you mentioned someone had issue like that
    09-18-2019 09:27 AM
  9. Asburner's Avatar
    Omg!!! Thank you!!! That was driving me crazy!!! That's so dumb it affects things outside of Google Play Books.
    09-18-2019 06:57 PM
  10. RyFeliciano's Avatar
    I have the same issue.
    I did try the Google Play Books trick, while it reduced the yellowing significantly, there is still yellowing when I use Google Photos and Gallery apps at night.
    This is turning me nuts. Ahahahah
    10-11-2019 09:20 AM
  11. Sarah_0521's Avatar
    Hello,
    I have the same issue with my Note 10 plus. I tried the trick with Google Play, but it doesn't change a thing.
    The yellow tint appears in the Kindle and Moonreader App.
    Now I got the Samsung Tab S6 and it has the same issue. I really loved to read but I can't look at the ebooks for 5 minutes. And then I am back on the internet to find a solution.
    There has to be something else to solve this.
    12-13-2019 09:53 AM
  12. Jeanice van Heerden's Avatar
    Hey Sarah
    I also use the Moonreader app. Go to your accessibility settings and try to change the colour correction there. I changed mine at colour adjustments (personalised colour) and increased the intensity to the highest level.
    Leo Andrei likes this.
    03-03-2020 09:21 AM
  13. Leo Andrei's Avatar
    Thank you, it actually worked. Or you can use the greyscale feature but it's bothersome to change it on and off. You can try other reading apps, it doesn't affect all of them, for instance pocket reader. But so far moon reader is my favorite and I was almost going to give it up because of the yellow tint.
    05-11-2020 10:28 PM
  14. mustang7757's Avatar
    Hi , welcome to AC!
    Glad it worked for you
    05-11-2020 10:34 PM
  15. paparazzo79's Avatar
    I can't find google play book app on play store.
    Link plz?
    05-17-2021 09:26 AM
  16. B. Diddy's Avatar
    Try this and see if it comes up: https://play.google.com/store/apps/d...hl=en_US&gl=US
    05-17-2021 11:05 AM
  17. mustang7757's Avatar
    Link plz?
    Same issue?
    05-17-2021 11:26 PM
  18. paparazzo79's Avatar
    Got msg:
    This item is not available in your country.
    05-19-2021 04:22 AM
  19. mustang7757's Avatar
    Got msg:
    Using any vpn or ad guards?
    05-19-2021 08:49 AM
  1. Note 10 audio zoom in feature
    By mustang7757 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-24-2019, 10:03 PM
  2. Screen Constantly Wakes - Pixel XL
    By EndRacism in forum Android 10
    Last Post: 09-24-2019, 07:19 PM
  3. Ported number from Tmobile not getting 2FA texts
    By MalachyNG in forum General Carrier Discussion
    Last Post: 09-17-2019, 08:41 PM
  4. Why did my device get hacked and my accounts
    Last Post: 09-17-2019, 01:54 PM
  5. want play video and jump 5 seconds
    Last Post: 09-16-2019, 10:10 PM
