Hi, Was looking for some help / confirmation on something as I'm going a bit insane looking for this option in the settings.
Note 10 plus user, currently have edge lighting enabled and always on display set to always.
Is there a way that when a notification comes in, only my edge lighting is enabled? currently what happens is a small pop up notification appears below the camera cut out with the message - however I would like it if only the edge lighting happened.
I did try turning off lock screen notifications and it worked, however my AOD doesn't update to show me I have a notification.
Hope this makes sense
