04-27-2020 06:11 AM
41 12
tools
  1. DARK Vader777's Avatar
    I've been using
    Ip Vanish and others at one time or another.
    They were great until this past week, it's slicing into my bandwidth big-time.
    I get 450 down. When activated it knocks me all the way down to 9-13 down.
    Just curious what's out there that doesn't cut into my bandwidth so much. I asked them, they said no changes were made. ๐Ÿค” Right?
    Any suggestions will be appreciated.
    It necessarily doesn't have to be free I can pay for it, but they're going to be slicing into it that much then I might as well not pay for one.
    Thank you.
    If there is a post for this, kindly merge. I apologize for any inconvenience mods.
    09-20-2019 11:24 AM
  2. Gary02468's Avatar
    I use my own VPN (OVPN server on a RPi4B). The RPi itself is the bottleneck, giving me 25-30 Mbps up & down. That's enough to stream video at 1440p, so it suffices for my purposes. (My RPi is connected by WiFi, and might give better VPN throughput with an ethernet connection.)
    09-20-2019 12:03 PM
  3. Rukbat's Avatar
    A VPN will reduce your bandwidth - there's no way to use a VPN without losing bandwidth (unless the VPN bandwidth is so great that you don't notice the small change, but it would cost big bucks for a VPN like that). Free VPNs seem to have lower bandwidth to start, so you end up with a greater reduction.
    For what? You're still ending up with the same external IP address, whether you're going through the VPN or you're connecting directly to the router.
    Hermes Hidayat likes this.
    09-20-2019 02:13 PM
  4. Gary02468's Avatar
    Yes, it's not intended to conceal where I'm connecting to (I wouldn't necessarily trust commercial VPNs for that either). It's for security when using public WiFi, and for bypassing carrier video-streaming "optimization" (throttling). Also, if I'm traveling abroad, it gives websites the impression I'm connecting to them from the US.
    09-20-2019 02:25 PM
  5. DARK Vader777's Avatar
    With her job she's wired into their intranet.
    They have their own software, proprietary information I'm not privy she says.
    I have to use a vpn for the payee system I use personally. No big deal I just noticed Ip Vanish slowed me way down.
    I've never been in the single digits with them.
    Always ran 20-26 down.
    I think I'm a go with Express VPN.
    7 day trial for free so wth. If I can get back up to at least 15 I'm good.
    My son came, took care of it and all is well.
    If that doesn't work CyberGhost it is.
    09-20-2019 09:44 PM
  6. Almeuit's Avatar
    Free? Never. Can't trust a free VPN.
    09-21-2019 02:53 AM
  7. Almeuit's Avatar
    You should have better experience with ExpressVPN. While a VPN does cause some overhead and speed drops.. it shouldn't be as drastic as from 400+ to not even 10.
    I use NordVPN and without it on I can get 300+ on wifi (more if I were to go to other wifi channels). With it on 100+ without issue... Just as long as I'm not trying to connect to Europe or something.
    jlangner likes this.
    09-21-2019 02:58 AM
  8. arunma's Avatar
    I'll be going to India over Christmas to visit some relatives. Can anyone recommend a good VPN that would let me use Netflix, Spotify, etc. while overseas as though I were back here?
    09-21-2019 08:27 AM
  9. toenail_flicker's Avatar
    will the vpns mentioned here block ads as well, or are they only for privacy concerns? thank you.
    09-21-2019 09:26 AM
  10. Gary02468's Avatar
    Running your own VPN server (in the US) on an RPi would be good for that. There's just a one-time cost of less than $50 for the device.
    If you connect to a commercial server, there's a chance Netflix etc. would recognize and ban the IP addresses they use.
    09-21-2019 02:09 PM
  11. Almeuit's Avatar
    ExpressVPN is great for that but expensive.. unless you are only going for a month then one month would be like $12-13. They have specific servers that are ensured to not be blocked by Netflix. You just contact their 24/7 chat and ask which one and they tell you right away. You connect and go.
    arunma likes this.
    09-21-2019 02:59 PM
  12. Almeuit's Avatar
    Most block ads and trackers as well.
    toenail_flicker likes this.
    09-21-2019 02:59 PM
  13. Almeuit's Avatar
    ExpressVPN is the only one I know that actively combats this by moving the servers around.
    09-21-2019 03:00 PM
  14. toenail_flicker's Avatar
    thank you.
    09-21-2019 03:20 PM
  15. arunma's Avatar
    Cool, thanks. ExpressVPN it is!
    09-21-2019 04:07 PM
  16. DARK Vader777's Avatar
    Express VPN on trust pilot grabbed 5 Stars.
    My son took care of it and it's 30 day Money back guaranteed.
    It's pricey, but rather pay more and worry less.
    Check it out for yourself
    ExpressVPN.com
    There's only a handful of VPN's that are truth worthy.
    Doing something you're not suppose to do then one should worry.
    For a helping hand in protection it is well worth it.
    No ads I've seen and my speed went from 8 down to 40 down.
    He also download a Torguard and a CyberGhost and Mullvad.
    I think I'll just keep Express.
    Running very smooth when needed.
    09-21-2019 04:13 PM
  17. DARK Vader777's Avatar
    I'm by far no expert an always turn someone who has experience.
    But the first thing he did was make sure I didn't have Nord VPN. He said they are trash. Hell I don't know.
    He told me to stay away from them.
    He's on the IT team for Agro. When he's here, everything gets fixed.
    ๐Ÿ˜‚
    I use to be about to use the Service my wife is logged into. Made a mistake by going on her laptop and searching for I'm a married man looking for a single woman๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚
    Nooo! I wouldn't of did that. They just updated their rules that's all. ๐Ÿ˜
    09-21-2019 04:27 PM
  18. Almeuit's Avatar
    They are pretty good. I'm in IT myself. Nord has one issue.. some servers get overloaded. So sometimes you have to connect to another place to get better speeds. That's the only issue I've run into with them.
    Once ExpressVPN puts in what Nord has for iPhone I'll switch. Which is auto connect when on WiFi. I have that always on so anytime I'm on wifi the VPN auto connects (screenshot below).
    So far only NordVPN has that for iPhones. The day ExpressVPN puts that in for their iOS app I'll swap.
    09-21-2019 11:11 PM
  19. anon(7901790)'s Avatar
    I use Private Internet Access. It's not free, and it doesn't affect my bandwidth TOO much.
    I just got 42Mbps down and 45Mbps up near Aloha Stadium.
    I use it mostly when I travel, especially over seas. When traveling in the US, I only connect to the hotel's WiFi. When I'm not at the hotel, I just use LTE.
    09-22-2019 10:00 PM
  20. wookiee2cu's Avatar
    I have NordVPN as well and like it quite a bit. Like mentioned earlier now and then I will have to switch servers because it gets overloaded but that's maybe once a week I have to do that. Works great on my home computer, phone, tablet and Amazon Fire Cube. The only draw I can think of is that it doesn't allow port forwarding but I don't think that is considered a high demand feature.
    09-27-2019 01:30 PM
  21. mukulb's Avatar
    Ya , i am using with no issues. I use psiphon... The connection speed is also good.
    09-27-2019 02:55 PM
  22. charlier180's Avatar
    I also use NordVPN on my notebook PC, Tablet and Note 10+. I usually get close to the maximum speed my home internet connection can give when using NordVPN.
    09-28-2019 09:56 PM
  23. Almeuit's Avatar
    I can get good speeds. Sadly no VPN gives me my full home speed since it's ridiculous lol.. but I've used ExpressVPN, Nord, and PIA. All are good in their own way.
    09-28-2019 11:55 PM
  24. DARK Vader777's Avatar
    Click image for larger version.ย
Views:	120ย
    Noted!
    Thanks
    09-29-2019 12:12 AM
  25. toenail_flicker's Avatar
    wanted to take a look at Nord today and geez their site is annoying. drove me away. won't even consider them now.
    10-31-2019 11:02 AM
41 12
  1. Anyone Using Google Fi?
    By Tigrisan in forum General Help and How To
    Last Post: 10-01-2019, 01:58 AM
  2. Replies: 3
    Last Post: 09-21-2019, 01:09 AM
  3. My phone keeps randomly playing the switch on tone
    Last Post: 09-21-2019, 12:52 AM
  4. Replies: 2
    Last Post: 09-20-2019, 03:02 PM
  5. Note 10+ Photo and Video Distortion
    By DJBrickman in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-20-2019, 09:29 AM
