1. vladfan's Avatar
    Whenever I get a notification, my lockscreen lights up. Is there a way to stop this from happening. I want to get the notifications on my AOD which I have and don't want to lose.
    09-20-2019 09:02 PM
  2. SpookDroid's Avatar
    Are all apps doing it? Usually the texting app does this, so using a 3rd party messaging app that allows to turn this iFeature (yes, I blame them for making this a thing) on/off
    09-21-2019 10:21 AM
  3. vladfan's Avatar
    It seems to be when I get a text message. I use the Textra app for messaging.
    09-21-2019 12:48 PM
  4. SpookDroid's Avatar
    Yup, just go to Textra's settings and you will find the option to turn the screen on (or not) when you get a text.
    09-21-2019 02:41 PM
  5. yarnsrj's Avatar
    Sorry I thought it was an EDGE LIGHTING issue.
    09-21-2019 04:32 PM
  6. yarnsrj's Avatar
    It looks like you may have to enable Do Not Disturb within the Notifications settings. From there you can turn on Do Not Disturb for specific times, and only allow certain apps or no apps. You will still see your Message alerts on your AOD, which is what you wanted. See how this works for you.
    ivantwilliams likes this.
    09-21-2019 05:06 PM
  7. msm0511's Avatar
    It looks like you may have to enable Do Not Disturb within the Notifications settings. From there you can turn on Do Not Disturb for specific times, and only allow certain apps or no apps. You will still see your Message alerts on your AOD, which is what you wanted. See how this works for you. [IMG=539x1024]https://uploads.tapatalk-cdn.com/20190921/f3c2e3e29d8958dbcc778a90669f22ad.jpg[/url][IMG=539x1024]https://uploads.tapatalk-cdn.com/20190921/3bd95e086e4196c828d635d67cd90df7.jpg[/url][IMG=539x1024]https://uploads.tapatalk-cdn.com/20190921/9c050ed48ea86a4938046a0106a6720b.jpg[/url]
    You don't have to do all that. There's a setting in Textra to turn it off.
    09-24-2019 09:52 PM
  8. yarnsrj's Avatar
    Ok didn't see that OP was referring to Textra. I thought it was for stock messaging. Just trying to help.
    msm0511 likes this.
    09-25-2019 01:55 AM
  1. No notifications on Samsung S10e
    Last Post: 09-21-2019, 12:46 AM
  2. Replies: 3
    Last Post: 09-21-2019, 12:15 AM
  3. Replies: 3
    Last Post: 09-20-2019, 03:30 PM
  4. Delete "Draft" Notification When Draft Isn't Present
    Last Post: 09-20-2019, 11:38 AM
  5. What does this new time zone notification even mean?
    Last Post: 09-20-2019, 10:49 AM
