09-29-2019 07:20 PM
28 12
tools
  1. grinchmcg's Avatar
    Hi. New Note 10 user. Great so far. One question.
    From what I have seen on this forum and online,
    there is no app or any setting to have some sort of LED notification
    with the Always on Display turned OFF. Is that correct ??
    All I would like is something that indicates I have a notification while the screen is off and it stays there until i look at it.
    09-21-2019 08:23 AM
  2. tatootie67's Avatar
    There's no led notification on our notes. We have edge lighting though. I do kinda miss the led but I've learned to accept it. Between using the AOD and edge lighting my needs are met. Also, there's the lift to wake feature, which will give you a peak at your notification without having to touch the screen.
    09-21-2019 09:14 AM
  3. GDany's Avatar
    I use Glimpse which wakes the screen for every notification I choose.
    sleepnclass likes this.
    09-21-2019 09:54 AM
  4. tsells's Avatar
    LED Me Know in Playstore is a great app, and replaces your LED notification with lots of options. However, you must use your Always on Display for it to work. There's a free version and a paid version. Paid version just has more options, but it is a great app and does not use much battery at all.
    https://play.google.com/store/apps/d...eknow&hl=en_US
    09-21-2019 10:41 AM
  5. chazglenn3's Avatar
    I don't believe there is a paid version of LED Me Know. The developer does accept donations, however. His app is the best substitute for the missing notification light IMO. The notifications are persistent and you can color code apps. You even get a charging animation. Highly recommended!
    09-21-2019 10:34 PM
  6. KupKrazy's Avatar
    The "paid" version is the 99 cent donation that pops up when you try to use certain patterns in the default notification, I believe.
    09-21-2019 11:45 PM
  7. chazglenn3's Avatar
    I see that now. Thanks. I enjoy this app and have now paid the 99 cents. A bargain for sure.
    09-22-2019 12:06 AM
  8. Bosbouer's Avatar
    The edge lighting + part of Goodlock also provide a sliver of light around the front camera provided that you pick tge black hole Edge Lighting option
    Attached Thumbnails NOTE 10  LED Notification-screenshot_20190922-091423_edge-screen.jpg
    09-22-2019 02:18 AM
  9. grinchmcg's Avatar
    The edge lighting plus is close, but only flashes once for a couple of seconds, then disappears.
    The LED Me Know I couldn't get to work right. Just got a green ring around hole all the time. Nothing when screen is off.
    09-22-2019 03:48 AM
  10. tsells's Avatar
    LED Me Know works perfectly and is actually fairly easy to set up. And the developer responds very quickly to any issues.
    Did you follow the very detailed instructions in the app to set it up properly?
    chazglenn3 likes this.
    09-22-2019 05:43 AM
  11. chazglenn3's Avatar
    LED Me Know works perfectly for me as well
    09-22-2019 07:15 PM
  12. grinchmcg's Avatar
    Does LED me know notifications show when screen is off and stay on until looked at ?
    toenail_flicker likes this.
    09-24-2019 09:17 AM
  13. tsells's Avatar
    Yes. But you must have your Always On Display active.
    09-24-2019 09:52 AM
  14. Johnston212's Avatar
    Have they made the Edge lighting into a persistent notification or is it still a blink and you missed it function?
    09-27-2019 11:03 AM
  15. toenail_flicker's Avatar
    this, when it works for me. wish they'd make it persistent until dismissed
    09-27-2019 11:10 AM
  16. xmsxphantasyx's Avatar
    I use an app called aodNotify. This app works exactly how I wanted because I don't want the AOD to be on all the time just to see notifications. I have the option to set it to turn on AOD only when there's a notification and it lights up around the camera hole too (you can set how long you want the flash to last). The AOD will turn back off after you clear the notification. In the pro version, there's a night time option to turn it off between so and so time to avoid turning on the AOD when notifications come in during that time like overnight.
    09-27-2019 04:01 PM
  17. grinchmcg's Avatar
    Sorry but no luck with LED me know. The developer is outstanding with tutorials and responding to questions.
    But i want an LED notification to both show and stay on when the screen is off until i dismiss it and this just can't do it.
    I know i'm not the only one who wishes they can do this and perhaps something will come out or updated to accomplish.
    It's really my only con about this great phone as of now.
    09-28-2019 08:21 AM
  18. Lepa79's Avatar
    I am amazed by all these LED notification apps that only work when AOD is on. Well great. Why in the heck I want LED light if the whole dang screen is on with AOD. useless at that point. I want to use LED notification because I don't want AOD on.
    toenail_flicker and STAJNRADO like this.
    09-28-2019 08:35 AM
  19. Lepa79's Avatar
    Just started using aodNotify today. Perfect. Only turns AOD when there are notifications and turns it back off when they are read .
    09-28-2019 12:13 PM
  20. grinchmcg's Avatar
    Lepa79,
    Confirm that this will show something on the screen when it is off and stay there until it is dismissed ?
    09-28-2019 01:07 PM
  21. toenail_flicker's Avatar
    when using aodnotify, are you forced to also see your charging % and icon when using it? mine is permanent now. and now there's a clock too. I want a black screen and only the edge light. thanks.
    09-28-2019 02:04 PM
  22. Lepa79's Avatar
    Lepa79,
    Yes. App will literary turns on AOD when your selected apps have notification (like new text or email), and AOD will stay on until you dismiss or read the notification. The Pro version gives you even more control. For example, turn off AOD when you unlock the phone and not necessarily read the notification or dismiss it. I like it very much.
    09-28-2019 04:06 PM
  23. jadenerd's Avatar
    Is there any way to have the clock on AOD with AOD? I couldn't configure it to see the clock so switched to Glimpse Notify.
    09-28-2019 08:31 PM
  24. Lepa79's Avatar
    Hmmm not sure what the issue is here. The clock is always present on AOD.
    09-28-2019 09:36 PM
  25. toenail_flicker's Avatar
    this and the battery charging info. I tried everything to make them both go away but had to give up on aodnotify ultimately.
    09-28-2019 09:40 PM
28 12
  1. WhatsApp Group Notifications Not All Making Sound
    By Android Central Question in forum Android Apps
    Last Post: 10-12-2019, 09:19 AM
  2. Notification makes Lockscreen light up.
    By vladfan in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-25-2019, 01:55 AM
  3. My Android is blocking Google Calendar notifications
    Last Post: 09-21-2019, 08:51 AM
  4. WTS: Still have my three Note 9 cases available
    By amyf27 in forum The Marketplace - Buy, Sell & Trade
    Last Post: 09-21-2019, 05:13 AM
  5. WhatsApp Group Notifications Not All Making Sound
    Last Post: 09-21-2019, 04:01 AM
