09-27-2019 04:12 PM
126 123 ...
tools
  1. Shaif's Avatar
    I have a Note 10 plus and I am wondering if I leave it plugged in overnight could do any harm. Because of the fast charging the note is maximum charing for a hour.
    If I wake up in the middle of the night I unplug the Note, but I don't always wake up in the middle of the night.
    How do you charge the Note?
    Thanks for the replies.
    09-23-2019 05:49 AM
  2. pool_shark's Avatar
    As with every phone I have had, I charge my phone whenever I want, including overnight.
    09-23-2019 06:11 AM
  3. rabernet's Avatar
    I leave it on the wireless charger next to my bed until the alarm goes off in the morning.
    09-23-2019 06:17 AM
  4. Lepa79's Avatar
    Why charge overnight? Phone charges from zero to 100 in one hour. When you wake up, put it on the charger. By the time you get done ready for the day, you have full charge.
    09-23-2019 06:43 AM
  5. Xxwabbit's Avatar
    I have mine on a smart plug.
    Shaif likes this.
    09-23-2019 06:54 AM
  6. burwil's Avatar
    I want to start the day with a full charge. It goes on an Anker USB charging station before I go to bed. There I can charge it slowly though it finishes well before sunrise. I don't think this does anything bad to battery health....my last phone, the Max, had 96% battery health after almost a year using this same process.
    spartanguy83, Scott337 and Shaif like this.
    09-23-2019 07:12 AM
  7. Gary02468's Avatar
    Except that some people are ready in much less than an hour. Or they need to carry their phone around and use it while they're getting ready. Why not charge it while you're asleep and not using it?
    09-23-2019 07:29 AM
  8. icnmayhem's Avatar
    I am far too lazy to stress about battery health. it inhibits my enjoyment of the phone. I charge it overnight, like most other people.
    09-23-2019 07:50 AM
  9. linkiik121's Avatar
    note 9 charged everyday overnight since day one for about a year and still has better battery life thn the note 10. didnt have any change in battery.
    Shaif likes this.
    09-23-2019 08:25 AM
  10. jlangner's Avatar
    I have always charged all of my phones over nite. Note 10+ leave on wireless instead of usb though.
    1raygin, Shaif and LadyEpic like this.
    09-23-2019 08:29 AM
  11. j_hansen's Avatar
    always charged my Notes 2/3/4/8/9 overnight and never had any battery issues
    tekjunkie28 and Shaif like this.
    09-23-2019 08:32 AM
  12. Lepa79's Avatar
    An hour from a ZERO. I guess people can't survive 30 to 40 minutes without looking at their phones?
    kj11, Apple2Droid and Shaif like this.
    09-23-2019 08:35 AM
  13. Gary02468's Avatar
    It has nothing to do with being unable to survive. Some people's phone-use needs differ from yours. We have phones for our convenience. Why inconvenience ourselves to benefit our phones, especially when there is likely to be no actual benefit?
    Shaif likes this.
    09-23-2019 09:31 AM
  14. Mooncatt's Avatar
    Prolonged dwelling at a high charge state (I.e. Above ~75%) can impact overall battery health, so I don't recommend it.
    https://batteryuniversity.com/index....ased_batteries
    Now if we still had removable batteries, this would be almost a non-issue. When you're looking at extended down time and a big cost to replace a sealed battery, you should at least know how to care for them the best way you can. How you choose to use that info is up to you.
    09-23-2019 09:54 AM
  15. Gary02468's Avatar
    Any use of your phone can impact overall battery health. Should we recommend keeping them powered off 90% of the time?
    Why buy an expensive phone if we're going to become its servant, rather than having it serve us?
    j_hansen, burwil, jlangner and 3 others like this.
    09-23-2019 10:04 AM
  16. toenail_flicker's Avatar
    mine is on a wireless pad during the night. I stream audio books before sleeping and whenever I wake up. this prevents battery drain while I sleep.
    I have AutomateIt Pro setup to dim my screen to 5% when placed on a charger and then invoke lock screen (no lock) so I can immediately tell if it is placed properly to charge. works really well like this.
    no heat or issues from the Anker pad so far. it's my first Anker charging product so I'm a bit wary. this model doesn't have a huge bright light or cause an echo while listening. I grabbed an extra one for the car.
    tried Samsung's last year model and it had a huge blue light and caused an echo. it's on its way back today.
    Shaif likes this.
    09-23-2019 10:05 AM
  17. Mooncatt's Avatar
    Even letting it sit on the shelf and not connected to anything they will eventually die. So using what I'm assuming is your sarcastic logic, why have battery powered phones at all?
    Yes, batteries will degrade. How you treat them will affect how quickly it does so.
    Shaif likes this.
    09-23-2019 10:49 AM
  18. j_hansen's Avatar
    I would rather pay for a battery replacement when/if time comes than going totally anal on charging habits for the sake of a few %
    batteries are a consumable whether they are built in or not
    09-23-2019 11:04 AM
  19. Gary02468's Avatar
    Not sarcastic at all. I honestly fail to see why convenient charging practices should be singled out as a recommended thing to sacrifice for battery conservation, rather than any of the other battery-draining (hence battery-cycling) attractions we could choose to sacrifice for the same cause (such as high-res video streaming, games, etc). Certainly the phone-care instructions in Samsung's user manual make no such recommendation about charging practices.
    The only charging practice I adopt for battery preservation is to use a slow-charging pad for overnight charging. I wouldn't gain any convenience from fast charging overnight, and slow pads are less expensive anyway.
    09-23-2019 11:13 AM
  20. gernerttl's Avatar
    This
    09-23-2019 12:55 PM
  21. gernerttl's Avatar
    And this.
    toenail_flicker and Shaif like this.
    09-23-2019 12:56 PM
  22. Mooncatt's Avatar
    If the OP asked about changing screen refresh rates, resolutions, mobile data vs Wi-Fi, or reduced battery consumption in general, I would've responded in kind. The reason overnight charging practices was singled out by me (and everyone else in this thread) is because that's specifically what was asked. I'm sorry you seem to take offence that I stayed on topic, even though it was with an unpopular opinion.
    MoreDef and Shaif like this.
    09-23-2019 01:20 PM
  23. amyf27's Avatar
    Same here. Use my wireless charge stand - also charges my watch. Leave them on overnight
    rabernet and Shaif like this.
    09-23-2019 01:20 PM
  24. Gary02468's Avatar
    No offense taken. I appreciate your opinion, and I'm merely expressing my own as well.
    Shaif likes this.
    09-23-2019 01:23 PM
  25. Mooncatt's Avatar
    I'd rather save the $100 or whatever the going rate is these days, and turning my phone over to a random person to replace my battery. Or to give it up entirely for a week or two for those needing to ship it to a service center. Charging options are so common place that it's rare I'm without access to power, so plugging in a little more often isn't an issue.
    09-23-2019 01:30 PM
126 123 ...
  1. Torras slim case & wireless charging pad
    By Bkdodger1 in forum Samsung Galaxy Note 10 & Note 10+ Cases & Accessories
    Last Post: 09-26-2019, 12:16 AM
  2. Tab S3 is NO LONGER charging...
    By Almazon in forum Samsung Galaxy Tab S3
    Last Post: 09-25-2019, 04:40 PM
  3. Use USB for ... > now out of charge. Help!
    By blueade7 in forum Ask a Question
    Last Post: 09-22-2019, 06:03 PM
  4. why is my phone not charging?
    Last Post: 09-22-2019, 03:54 AM
  5. Phone will only charge on car plug
    Last Post: 09-21-2019, 04:12 PM
