09-24-2019 09:11 PM
27 12
tools
  1. toenail_flicker's Avatar
    I remember seeing this here once before and can't find the thread with the answer as to the resolution. my phone rings and I have the options to answer shown but pressing them does nothing. there is a fly up from the bottom but only to send message, etc. any ideas folks. I don't use the phone that much but need it when I need it, you know. thanks all.
    09-24-2019 11:30 AM
  2. rabernet's Avatar
    Mine did that one time. I hit the volume rocker up, I think, just one quick tap, and then was able to swipe the screen as normal. It was weird when it happened. After that one time, I was able to answer calls normally.
    toenail_flicker likes this.
    09-24-2019 11:50 AM
  3. toenail_flicker's Avatar
    I don't use swipe and there are buttons, both were lit/flashing but neither one responded to touch as in the past.
    09-24-2019 12:42 PM
  4. mustang7757's Avatar
    Have you tried in the dialer app settings can choose to answer calls with volume up and end calls with side keys?
    09-24-2019 12:51 PM
  5. toenail_flicker's Avatar
    Thanks for the tips.
    Really want my buttons to work again though. Using those options isn't intuitive for me.
    mustang7757 likes this.
    09-24-2019 01:04 PM
  6. mustang7757's Avatar
    Your welcome, just make sure a application is not interfering with lock screen like Nova launcher check in administrator settings
    09-24-2019 01:31 PM
  7. wdfrancis58's Avatar
    I'm on Sprint and I have to answer with pressing on the button and swiping it left or right to either answer it or send it to voicemail.
    09-24-2019 01:51 PM
  8. toenail_flicker's Avatar
    can't figure out what's causing this so I set things to answer this way. I'm going to check galaxy store for any update that might help this and probably take the update that just came through today.
    09-24-2019 06:17 PM
  9. toenail_flicker's Avatar
    the weird thing is that the buttons worked when I tested the phone initially and several times since. very odd.
    09-24-2019 06:18 PM
  10. rabernet's Avatar
    I'm not familiar with buttons - is that something you set up? Or is that determined by carrier? Or maybe even a different launcher? Genuinely want to know.
    I get a green phone "button" and red phone "button" and I have to swipe one or the other to either answer a call or decline a call (or just turn the phone over to silence a call).
    09-24-2019 06:28 PM
  11. mustang7757's Avatar
    When did this start happening?
    Do u. Use Nova?
    That's definitely alternative.
    09-24-2019 06:32 PM
  12. toenail_flicker's Avatar
    It's this. Can't swipe anything.
    09-24-2019 06:35 PM
  13. toenail_flicker's Avatar
    No. I use apex. I've had the phone about two + weeks and I answered calls last week
    Do u. Use Nova?
    09-24-2019 06:37 PM
  14. toenail_flicker's Avatar
    I get a green phone "button" and red phone "botton" and I have to swipe one or the other to either answer a call or decline a call (or just turn the phone over to silence a call).
    I finally got it to swipe, but I have to swipe hard and far.
    anyway to turn this off so I can just press the buttons to answer? it wasn't setup like this at first.
    09-24-2019 06:41 PM
  15. mustang7757's Avatar
    Try using the stock launcher to test this out
    09-24-2019 06:41 PM
  16. toenail_flicker's Avatar
    I'm wondering if it's the theme I'm using, which would really suck because I like it a lot. I've been using apex since day one so I don't see where that would do it.
    09-24-2019 06:44 PM
  17. toenail_flicker's Avatar
    it's not apex and it's not the theme
    09-24-2019 06:48 PM
  18. mustang7757's Avatar
    Administrator
    09-24-2019 07:15 PM
  19. toenail_flicker's Avatar
    Administrator
    09-24-2019 07:25 PM
  20. mustang7757's Avatar
    In settings type administrator should be only find my phone
    09-24-2019 08:16 PM
  21. toenail_flicker's Avatar
    unclear how that relates, but Package Disabler Pro also has admin rights by necessity
    09-24-2019 08:47 PM
  22. toenail_flicker's Avatar
    I removed admin rights for it and it didn't help anything. really hate having to swipe.
    09-24-2019 08:54 PM
  23. mustang7757's Avatar
    Because it can change lock screen behavior and different permissions
    09-24-2019 08:59 PM
  24. mustang7757's Avatar
    Test this out temp to see if causing issues
    09-24-2019 08:59 PM
  25. toenail_flicker's Avatar
    thanks but already tried and it didn't help anything. I also don't use any kind of lock screen
    09-24-2019 09:03 PM
27 12
  1. Can't disable Google Chrome and Photos apps
    By nuficek in forum Huawei Mate 20 & Huawei Mate 20 Pro
    Last Post: 10-13-2019, 09:16 PM
  2. Replies: 9
    Last Post: 09-24-2019, 04:18 PM
  3. On topic recent cell phone battery article
    By methodman89 in forum Ask a Question
    Last Post: 09-24-2019, 02:57 PM
  4. Why can't open webpage on my galaxy j3 phone
    Last Post: 09-24-2019, 12:41 PM
  5. How can I get the actual day of the week displayed on the phone
    Last Post: 09-24-2019, 12:36 PM
