1. donb2010's Avatar
    I noticed that every time I restart my Note 10+ the AOD and Lock screen seems to reset itself. Only when I unlock and get into my home screen and after a few seconds everything seems to go back to how I have the AOD and Lock screen set up. Anyone else noticed this? how to fix?
    09-26-2019 04:23 PM
  2. anon(7901790)'s Avatar
    I haven't noticed it. Are you using a 3rd party launcher like Nova or Microsoft Launcher?
    09-26-2019 04:26 PM
  3. mustang7757's Avatar
    I don't restart my phone often , do have a launcher or application that can change lock screen?
    09-26-2019 04:26 PM
  4. Sophos's Avatar
    Are you sure it needs fixing? There are some features/info that are not available after restarting your phone until you unlock it for security reasons.
    11B1P likes this.
    09-26-2019 04:31 PM
  5. donb2010's Avatar
    Yes, Nova Launcher, but I didn't notice this happening with my Note 9.
    09-26-2019 04:50 PM
  6. donb2010's Avatar
    Not features/info, I'm referring to the set up I have for AOD (Clock Style) and Lock screen (Wallpaper).
    09-26-2019 04:52 PM
  7. bbgpsuser's Avatar
    Nova Launcher won't run until after you unlock your phone after a restart.
    09-26-2019 04:52 PM
  8. donb2010's Avatar
    I know, but I don't use Nova Launcher for AOD or Lock Screen. I have set a specific "Clock Style" for AOD and a specific wallpaper for Lock Screen, but as I mentioned they both seem to reset after I restart my phone and only after I unlock and get into my home screen does the AOD and Lock Screen revert to the "Clock Style" and wallpaper I set before restarting my phone. This was not an issue with my Note 9.
    09-26-2019 05:02 PM
  9. mustang7757's Avatar
    Double check Nova settings by lock lock method
    Screen shot:
    AOD and Lock Screen after a restart?-screenshot_20190926-171012_nova-20launcher.jpeg
    09-26-2019 05:12 PM
  10. anon(7901790)'s Avatar
    Ah. I use Microsoft Launcher. But, yeah, Nova Launcher could have changed something. I haven't used it in years, mustang7757 would be able to help you out.
    09-26-2019 05:57 PM
  11. mustang7757's Avatar
    I'll try ..
    09-26-2019 05:58 PM
  12. anon(7901790)'s Avatar
    I'll try ..
    mustang7757 likes this.
    09-26-2019 06:06 PM
  13. mustang7757's Avatar
    Hahaha
    Use the force... Click image for larger version.
    anon(7901790) likes this.
    09-26-2019 06:08 PM
  14. msm0511's Avatar
    Don't you mean The Schwartz?
    mustang7757 and anon(7901790) like this.
    09-26-2019 09:29 PM
  1. Images and videos are automatically getting deleted, android pie...
    Last Post: 09-28-2019, 01:07 PM
  2. Widgets broken after update?
    By Mooncatt in forum LG V20
    Last Post: 09-26-2019, 02:29 PM
  3. LTE w/ House and Wifi Icons
    By pizza_pablo in forum Samsung Galaxy Note 9
    Last Post: 09-26-2019, 01:53 PM
  4. I have an app that using gcm and we are migrating to fcg
    Last Post: 09-26-2019, 01:38 PM
  5. Replies: 1
    Last Post: 09-26-2019, 12:54 PM
