09-29-2019 01:30 PM
27 12
tools
  1. mjs2011's Avatar
    For some reason, my phone switched to 3g and no matter what I've tried, it won't come back. I've put the phone in Airplane Mode, toggled data, changed it from CDMA to Global. Nothing.
    Confirmed that there is nothing wrong on the carrier end too.
    Any thoughts on what else I can try?
    It's the unlocked model using US Cellular.
    09-27-2019 05:42 PM
  2. egood71's Avatar
    Is this an ongoing issue or just recently? Maybe the tower is in maintenance mode.
    Just a thought...
    mjs2011 likes this.
    09-27-2019 05:43 PM
  3. toenail_flicker's Avatar
    and you've checked your phone mobile networks settings, Network Mode to be sure it's set to LTE/CDMA?
    09-27-2019 05:48 PM
  4. mjs2011's Avatar
    It's always been set to Global since I set the phone up and activated it.
    toenail_flicker likes this.
    09-27-2019 05:51 PM
  5. toenail_flicker's Avatar
    fair enough. not sure I have that but wanted to be sure something was set to other than cdma
    09-27-2019 05:54 PM
  6. mjs2011's Avatar
    I'm glad you said that though. I switched just for fun and rebooted and now I have LTE!
    09-27-2019 05:57 PM
  7. toenail_flicker's Avatar
    cool! glad it helped! I know I'm supposed to be on lte/cdma, but that setting pulls my signal down so I set it to cdma while at home because even if I'm really lucky, that's all I'm going to get anyway.
    Nostromo79 likes this.
    09-27-2019 07:03 PM
  8. tekjunkie28's Avatar
    Lol I started reading through this thread and I wondering.... this is odd. Have have a US cellular outage here now due to tower upgrades. I guess some users could bounce off the other tower but idk. I saw some guys working on the tower today and stopped by. I was hoping they were installing a new Verizon macro but no luck. They were changing out panels for us cellular.
    09-27-2019 07:08 PM
  9. Mike Dee's Avatar
    It should have worked in Global but glad it's working for you
    09-27-2019 09:03 PM
  10. toenail_flicker's Avatar
    that's what I was thinking
    09-27-2019 09:08 PM
  11. mjs2011's Avatar
    Yeah this is a bit concerning. I went back to global and it's still at 3g. I don't know if there's any downside to being on LTE/CDMA but I'm not sure why it would just stop working.
    09-27-2019 09:20 PM
  12. mjs2011's Avatar
    And it's not the first time it happened. I was having issues with low serviced areas switching to 3g and not immediately switching back. But this is the first time I couldn't get it to switch back at all.
    09-27-2019 09:26 PM
  13. toenail_flicker's Avatar
    did you try a reboot, wipe the external cache, or update your ?prn or ?profile? don't know that any of that would help, but those are the first things I try when I'm having issues, the last two being phone specific and that's the only reason I try them.
    09-27-2019 09:41 PM
  14. mjs2011's Avatar
    I don't have an option for prn/ profile. Not sure how to do external cache though. Several reboots
    09-27-2019 09:43 PM
  15. toenail_flicker's Avatar
    do you have any apps/services blocked? I do and I noticed mine aren't available either, but they are there normally. they are standard phone service things that can be updated and then your phone reboots
    09-27-2019 09:58 PM
  16. mjs2011's Avatar
    I definitely don't but I know profile/prn normally isn't present on us cellular.
    I'll probably try another phone call with the carrier just to make sure there's nothing wrong. Otherwise maybe I'll factory reset the device.
    09-27-2019 10:01 PM
  17. tekjunkie28's Avatar
    I don’t have that available either. I think it’s only on older androids or CDMA networks. That’s what those things are for anyways. PRL is for CDMA and profile, I believe, is the same as carrier updates on iPhones. Which is for LTE.
    09-27-2019 10:04 PM
  18. toenail_flicker's Avatar
    mystery solved. you won't have update profile seems it's a cdma thing and prn won't apply in this situation anyway
    tekjunkie28 likes this.
    09-27-2019 10:04 PM
  19. mjs2011's Avatar
    Welp. Went back to Global and it works. This is quite the mystery to say the least.
    09-27-2019 10:52 PM
  20. toenail_flicker's Avatar
    that was what I was thinking. if it was working in lte mode then it logically should work in global too. my devices always have a mystery or two in store for me
    09-27-2019 11:03 PM
  21. Mike Dee's Avatar
    Maybe your device was just having a bad day
    09-28-2019 04:01 PM
  22. mjs2011's Avatar
    Unfortunately it did the same thing today so I switched to CDMA/LTE again.
    09-28-2019 04:06 PM
  23. toenail_flicker's Avatar
    this is so weird. maybe a bad sim? worth reaching out to your carrier?
    09-28-2019 04:16 PM
  24. mjs2011's Avatar
    That's actually my hunch at this point. I see nikki other reason why it would just stop working.
    09-28-2019 04:17 PM
  25. Mike Dee's Avatar
    By the way there's nothing wrong with leaving it on CDMA/LTE. Global is just a universal mode in case you are going out of the country or roaming into any area with GSM.
    I would try a different sim just in case its flakey.
    09-28-2019 04:30 PM
27 12
  1. Speaker on Motorola G6 play not working after update
    By Android Central Question in forum Moto G6 Play
    Last Post: 09-28-2019, 01:59 PM
  2. Replies: 2
    Last Post: 09-28-2019, 01:55 PM
  3. Notification (alerts) stopping audio
    By iFortWorth in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-27-2019, 11:25 PM
  4. Speaker on Motorola G6 play not working after update
    Last Post: 09-27-2019, 02:58 PM
  5. External Keyboard, language switch shortcut not working
    Last Post: 09-27-2019, 09:24 AM
