1. srgonu's Avatar
    How is the battery life on note 10? Is it as good as the 10+?
    09-29-2019 11:53 PM
  2. bandofbrothers2112's Avatar
    I've not used the Note 10 but I wouldn't think it would be the same as the N10+ due to battery size difference.
    Note 10 is 3500mAh
    Note 10+ is 4300mAh
    I use the N10+ 5G and can get 2-3 days usage however I always power down my phone at night as it's not needed during those hours.
    Battery stats are a subjective topic as we all set up our phones differently, have different preference settings in the phone , use different apps, have different usage habits and have different signal strengths.
    09-30-2019 12:29 AM
  3. j_hansen's Avatar
    Biggest power drain is always screen brightness so depending on where you use your phone most will be a big factor, sunny country and mainly outdoor use will zap it nearly twice as quick as mainly indoor use in less sunny places
    09-30-2019 06:21 AM
  4. Pynk_moscato_18's Avatar
    Battery life is subjective like those above me said. But I have the regular note 10 and this is what my battery life looks like currently on medium power saving mode and location on, so not bad I guess. A lighter user can probably stretch their standby time out a couple more hours based on those settings.
    10-01-2019 04:59 AM
  5. toenail_flicker's Avatar
    Battery life is subjective like those above me said. But I have the regular note 10 and this is what my battery life looks like currently on medium power saving mode and location on, so not bad I guess. A lighter user can probably stretch their standby time out a couple more hours based on those settings. [IMG=485x1024]https://uploads.tapatalk-cdn.com/20191001/8aaf6fa08dc87e432cdccd8aa5fd9e47.jpg[/url]
    what is sleep pillow? can't find it on GP
    10-01-2019 07:11 AM
  6. Pynk_moscato_18's Avatar
    It's a white noise app for sleep. It should be the first app when you type sleep pillow on the Google store.
    Apple2Droid likes this.
    10-01-2019 08:38 AM
  7. toenail_flicker's Avatar
    thanks. It should be the first app when you type sleep pillow on the Google store.
    I get a slew of sleep apps but not that one
    10-01-2019 09:11 AM
  8. Pynk_moscato_18's Avatar
    It's the first one with the blue owl in the picture.
    10-01-2019 10:26 AM
  9. toenail_flicker's Avatar
    ah. thank you. would be nice if it was named sleep pillow. the app name is different. thanks
    10-01-2019 10:56 AM
  10. Pynk_moscato_18's Avatar
    No problem I know, I always thought that was the name but I guess not lol.
    10-01-2019 12:03 PM
  11. toenail_flicker's Avatar
    actually that IS the name. they chose not to show the name, but rather the description, in GP, as the name. once installed, I found it under sleep pillow. weirdness. I liked it and so did my dogs, but too ad heavy for my tastes. started hitting me up for money immediately. I already own so really great ones so no need to pay their prices for each one. I was just curious. thanks again.
    Pynk_moscato_18 likes this.
    10-01-2019 02:19 PM
  12. Pynk_moscato_18's Avatar
    No problem. I did pay for the ad-free version a couple years ago and have been using it ever since. They have a good mix of sounds to help me sleep.
    toenail_flicker likes this.
    10-01-2019 05:23 PM
  13. toenail_flicker's Avatar
    I saw no version but that one and what it offered me was the option to pay $1.99 each for about 12 items or so. not gonna happen. I do appreciate it though. and I'd certainly pay a one-time fee, but not endlessly or with so many nags.
    10-01-2019 05:29 PM
  14. Apple2Droid's Avatar
    Sleep Pillow allows you to mix sounds, which is great for Type A personalities especially. The mixture of sounds confused my brain, which helps me fall asleep easier. There's a nice mix one in the free version that I've always used, but the paid version let's you mix your own and also gives you longer sleep timers.
    10-01-2019 07:41 PM
  1. "Color Point" pictures taken with the Note 10
    By scorpio1984 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-05-2019, 09:24 PM
  2. Galaxy Watch Bundle on EBay
    By Dee74 in forum Samsung Galaxy Watch
    Last Post: 10-11-2019, 01:19 PM
  3. What is this mysterious icon? Note 8
    Last Post: 10-06-2019, 04:50 AM
  4. Number on google app
    Last Post: 09-30-2019, 01:07 PM
  5. SPRINT Note 10 5G Version when???
    By Oscar Maradiaga in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-29-2019, 09:10 PM
