11B1P
Trusted Member
I think so. I don't use it for the points, though that is a nice little benny. I use it because it is freaking USEFUL.
Yep, I agree
The best is US post offices. They don't know eitherI use Samsung Pay at the local Kroger and frequently get the “we don’t take Apple Pay” comment. The cashier is surprised when it goes through. I admit that I feel a little smug when that happens.
Except it's easy for someone to steal your card info in those. I don't use the trick either though.if you use the card trick, might as well use a payment card
I use it at Walmart all the time and never have a problem. Sometimes I use it at the self-checkout sometimes I have to do it twice but it works.
I think those rewards are for online orders.I started using it at Walmart again and no problems. so much faster than trying to use walmart pay. the only thing I don't like is the terminals do no make it easy for it to tell you that the payment went through. The beep is usually followed by a card error because I held the card at the scanner too long. fortunately the payment did processed.
lately when I opened samsung pay app, there is a notification about rewards for using it at walmart. makes me wonder if walmart had a change of heart and not blocking sp as they seemed to do in the past.
And Samsung points are worthless now? Did they change it where you can't trade Samsung points for gift cards any more?
Exactly. It's too bad Samsung changed it too.I wouldn't say they are worthless, just that it takes more transactions to accumulate the same amount of points as when they first started
That sounds familiar. I don't use it as much because they cut back the points you're able to earn
