1 Attachment(s)
Frustrating Android auto problem (fixed)
So for the last few days I could not get Android auto to play sound with my Note 10+ works fine with my S10+. Turns out using Goodlocks multistar and having multi sound checked was causing sound not to play when using Android auto. In case anyone else is having this problem try this it worked for me.
Re: Frustrating Android auto problem (fixed)
Thanks for the tip! I'm sure it'll help others if they're experiencing that issue! I've had way too many issues (granted, most are user-related because I forget that is active) when using Dual Audio and Multi Sound, so I just turn it off now.
