1. jwatson77's Avatar
    Anyone having issues with frequently dropped calls?
    SARCtech likes this.
    10-07-2019 10:04 AM
  2. bulls96's Avatar
    Nope. Have unlocked on t-mobile.
    10-07-2019 10:26 AM
  3. o4liberty's Avatar
    Same here unlocked tmobile sounds like you have a carrier issue what carrier are you with?
    10-07-2019 10:34 AM
  4. hooligan03's Avatar
    no dropped calls on Vzw.
    10-07-2019 02:11 PM
  5. gernerttl's Avatar
    No dropped calls. Verizon.
    10-07-2019 05:05 PM
  6. msm0511's Avatar
    I haven't dropped any calls, but my calls aren't all that clear.
    10-08-2019 09:20 PM
  7. rabernet's Avatar
    Verizon - no dropped calls.
    10-09-2019 06:26 AM
  8. jwatson77's Avatar
    Tmobile. Seems to drop call every 15 minutes.
    10-10-2019 04:29 PM
  9. jwatson77's Avatar
    Tmobile. Seems to drop calls every 15 minutes.
    10-10-2019 04:29 PM
  10. wookiee2cu's Avatar
    Tmobile, locked and no dropped calls, I've had the phone for about 2 weeks now.
    10-14-2019 03:55 PM
  11. SARCtech's Avatar
    I'm using Mint mobile (MVNO that uses T-Mobile network) and I have problems with dropped calls due to poor signal in part of my home. The big problem I have is WiFi calling works intermittently, the phone is automatically changing my WiFi preferences to prefer mobile network, and then the other major issue I'm having is texting....messages fail to send but the recipient gets the same message multiple times....or the message says it was sent and the recipient never received it.
    I posted a thread about my disappointment with this device. I have pre-ordered the Pixel 4 XL today and will be getting rid of this device. Its useless if it can't perform basic functions expected of a phone....especially one at this price point.
    10-15-2019 02:47 PM
  12. o4liberty's Avatar
    Tmobile unlocked no dropped calls at all.
    10-15-2019 03:31 PM
  13. Laura Knotek's Avatar
    No dropped calls or WiFi calling issues on Verizon for me. Clarity is fine.
    mustang7757 likes this.
    10-15-2019 04:03 PM
  14. buzzy3970's Avatar
    I'm unlocked on Verizon and experience drop calls frequently in my house. Wi-fi calling seems to help. Didn't have that issue with my S10+.
    10-16-2019 03:39 AM
  15. o4liberty's Avatar
    Sounds like a reception issue to me what is your signal like when you drop calls.
    10-16-2019 09:57 AM
  16. cardboard60's Avatar
    Had to call verizon on the phone to turn on wifi Calling.
    Seems the government wants you to setup 911 address and everything on your phone before wifi Calling will work.
    If everything else fails.
    Take it to your carrier.
    Good Luck.
    10-16-2019 10:21 AM
  17. trucksmoveamerica#AC's Avatar
    Yup. It happens in weak areas, the s10+ did the same thing. Note 9 no dropped calls in same area.
    10-16-2019 01:08 PM
  18. cardboard60's Avatar
    You could be caught in between 2 tower areas.
    Or trees are moving when the wind blows.
    Call your carrier.
    10-16-2019 01:26 PM
  19. tekjunkie28's Avatar
    The note 10 and the s10+ are known to have noticeably weaker signal.
    10-19-2019 08:59 AM
  20. trucksmoveamerica#AC's Avatar
    They do, some just don't want to see it.
    tekjunkie28 likes this.
    10-19-2019 09:08 AM
  21. tekjunkie28's Avatar
    One reason I can’t own a note 10+. At least not as a my main phone.
    10-19-2019 09:09 AM
  22. cardboard60's Avatar
    Have you tried to call the calling the carrier with your phone and ask them what the problem might be ?
    10-19-2019 09:51 AM
  23. tekjunkie28's Avatar
    No. I’m using a iPhone pro max now and it’s flawless but I still feel like I want the Note. Especially now that the not is $500 less then the pro max. I’m just insecure anout some thing the note does
    10-19-2019 09:52 AM
  24. trucksmoveamerica#AC's Avatar
    No, those 2 phones drop the calls every time in bad areas that the note 9, S9, and older versions do not drop the calls. The S10 and note 10 series have worse antennas or something, it's not a carrier thing. I've seen several complaints from all carriers from ones that are willing to admit there's a signal issue.
    10-19-2019 09:58 AM
  1. new nest hub max keeps dropping internet connection
    By farmwersteve in forum Google Nest Home Max
    Last Post: 10-20-2019, 11:21 AM
  2. Phone screen goes off during calls
    Last Post: 10-13-2019, 09:42 AM
  3. phone calls people can only hear me when on speaker phone
    Last Post: 10-07-2019, 12:53 PM
  4. Why is my note 10 plus battery dropping from 5 or 4 percent straight to zero
    Last Post: 10-06-2019, 02:08 PM
  5. Wi-Fi calling on Samsung Galaxy Note 3
    Last Post: 10-06-2019, 01:53 PM
