10-22-2019 01:18 PM
56 123
tools
  1. mustang7757's Avatar
    How do I get more stats without root?
    You do need root it already provide enough without it
    10-09-2019 09:41 PM
  2. toenail_flicker's Avatar
    Instagram too
    I only use it to post certain pictures and then I disable it when finished. for reading, viewing, liking I use desktop for the ad blocking. can't take the onslaught of ridiculous ads.
    10-09-2019 09:55 PM
  3. Lecrae116's Avatar
    What info should I be looking for within gsam?
    10-09-2019 10:04 PM
  4. mustang7757's Avatar
    It will show your signal , on wifi or data
    Give it full 24 hours to report stat from 100 percent that way we can diagnose correctly like how you did with stock battery built in monitor.
    10-09-2019 10:19 PM
  5. burwil's Avatar
    Accubattery is good also.
    10-09-2019 11:28 PM
  6. Serkle K's Avatar
    My battery was pretty bad after the first 3 days with my Note10+. Then after about a week from there, it improved greatly. I did have to wipe and only restore contacts, calendars, and messages. Everything else I had to reinstall manually. My main issue was Android System app. I have also basically disabled a good majority of my apps from running in the background.
    10-10-2019 11:54 AM
  7. Lecrae116's Avatar
    I know it hasn't been 24 hours but this is not good at all.
    10-10-2019 01:17 PM
  8. mustang7757's Avatar
    I know it hasn't been 24 hours but this is not good at all. [IMG=360x760]https://uploads.tapatalk-cdn.com/20191010/be1b5e45a008fb1b7d5cfb20c64b997b.jpg[/url][IMG=360x760]https://uploads.tapatalk-cdn.com/20191010/51003c9b67f9306fb9c5fcbc826d96de.jpg[/url][IMG=360x760]https://uploads.tapatalk-cdn.com/20191010/5e3f96e6fda1de304a198e8df0206e4b.jpg[/url]
    Phone radio - getting high , you use mobile data alot ? How's your cell phone reception?
    10-10-2019 01:48 PM
  9. Lecrae116's Avatar
    90% of the time during the dust me im not near wifi so Mobile data has to be used.
    10-10-2019 11:20 PM
  10. mustang7757's Avatar
    If you use data more then wifi especially 90 percent of the time then your battery I would say be like your stats.
    Laura Knotek likes this.
    10-10-2019 11:33 PM
  11. Lecrae116's Avatar
    My phone doesn't want to deep sleep at all.
    10-13-2019 11:03 PM
  12. mustang7757's Avatar
    My phone doesn't want to deep sleep at all. [IMG=485x1024]https://uploads.tapatalk-cdn.com/20191014/56d6838ab22945afb177ef103d6309cf.jpg[/url][IMG=485x1024]https://uploads.tapatalk-cdn.com/20191014/79c522025eec3d38728e56c9e29496c6.jpg[/url][IMG=485x1024]https://uploads.tapatalk-cdn.com/20191014/40285bcce9ab78aa1b07c69684e19f0b.jpg[/url]
    Probably notification
    10-13-2019 11:24 PM
  13. Lecrae116's Avatar
    notification from What?
    10-14-2019 07:47 AM
  14. mustang7757's Avatar
    Apps ? Facebook, Instagram, messages,etc.
    10-14-2019 10:43 AM
  15. Lecrae116's Avatar
    All those notifications are OFF except for text messages and calls.
    10-14-2019 10:50 AM
  16. mustang7757's Avatar
    Is AOD on
    10-14-2019 10:52 AM
  17. Lecrae116's Avatar
    Is AOD on
    No
    10-14-2019 10:54 AM
  18. mustang7757's Avatar
    No
    Strange ..youll have to dig little more deeper into that battery app if you can find something
    10-14-2019 11:21 AM
  19. Lecrae116's Avatar
    How much does yours deep sleep?
    10-14-2019 11:45 AM
  20. mustang7757's Avatar
    I never tested it out , I usually get very good battery life but I can report back in 24 hours let you know
    10-14-2019 11:48 AM
  21. tekjunkie28's Avatar
    What have you found?
    10-19-2019 09:43 AM
  22. mustang7757's Avatar
    Never tested , OP didn't respond I should test it.
    10-19-2019 09:55 AM
  23. Lecrae116's Avatar
    Sorry for the delay. Let us know the results.
    10-20-2019 12:59 AM
  24. mustang7757's Avatar
    Ok, I'll start tommorow 24 hours from then
    10-20-2019 01:00 AM
  25. mustang7757's Avatar
    Ok I will load up my stats
    tekjunkie28 likes this.
    10-22-2019 12:25 PM
56 123
  1. Weird Battery Behavior
    By Serkle K in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 01-27-2020, 03:54 PM
  2. What app uses this symbol?
    By 1musicLover1982 in forum Ask a Question
    Last Post: 10-10-2019, 12:03 PM
  3. why is has "move to IOS" stopped
    Last Post: 10-09-2019, 01:19 PM
  4. Does Anyone know what app this symbol is for?
    Last Post: 10-09-2019, 01:04 PM
  5. What is best combination of Otterbox - Screen Protector for Apple XR?
    Last Post: 10-09-2019, 05:58 AM
