I own both devices and here is my quick take on both.
Note 10 +
I purchased the Note on day one and by far it’s been the best device for me to date. With developer options tweaked on my note and the 12 gig of ram my note is 100% lag free and super fast all the time. The camera most of the time takes awesome photos and with some tweaks they get even better. The size is perfect not too big and not too small. The Samsung one UI works perfect very one handed friendly. The screen is beautiful to look at haven’t seen any screen better. All in all this device couldn’t get any more perfect.
IPHONE 11 PRO MAX
The iPhone OS 13 is very buggy which I am sure an update will fix the known issues. The screen is nice very close to the note but not as good IMO. The camera is very nice almost neck and neck to the notes photos. As far as ease of use and speed the note kills the iPhones UI not one handed friendly and much slower. The size is just as good as the note no issue there. The current lag is coming from OS issues which will get fixed.
Both devices are very nice but in the end the Note 10 + is the winner with me due to its speed and ease of use.
I have the animations tweaked in developer mode which make the note super fast.
what do you have them set to? I had changed mine to my standard of .5 but was concerned it might be causing issues so changed them back. your input would be appreciated.
any other tweaks you've made in developer mode would be nice to know too.
Hmmm... What do you mean "might be causing issues"? I always set animations to OFF...
Owh hahaha. I used to be OCD to slow moving animations... Glad it could be turned off...
I don't care for them in general myself. I generally set the ones in dev options to .5 so that I can still move icons around, but don't see a lot of effect from them otherwise. I didn't know there were settings in general & accessibility but saw them while searching so turned them off too.
If youre up for some fun, try setting them to x10. I just did it and its fun xD.
It's build in my Custom Samsung Theme called Wicked Venom, not in Samsung theme store either, it's my own personal Samsung theme.
As you can see no AT&T on top left status bar i took that off the AT&T logo text and i removed it from notifications panel as well, they are mods i added to my custom Samsung theme.
