1. surfinguru2000's Avatar
    Currently set to LTE/UMTS auto (PRL). Is this the correct setting for ATT?
    Samsung branded /unlocked handset FWIW.
    Thanks!
    10-17-2019 03:17 PM
  2. anon(19759)'s Avatar
    Just leave it the way it came.
    10-18-2019 04:00 PM
  3. surfinguru2000's Avatar
    Well, if I could remember what those were, I wouldn’t have had to ask. So, can anyone post up what their settings are?
    *#*#4636#*#*
    Device information
    Set Preferred Network Type = ?
    10-19-2019 12:06 PM
  4. gsparks2's Avatar
    I have Samsung unbranded, unlocked Note 10+ on ATTNeed Preferred Network Type settings for Note10+ on ATT-screenshot_20191019-210618_settings.jpeg
    10-19-2019 09:07 PM
  5. burrzoo's Avatar
    I hope this helps in some way. I realize that you have an Unlocked phone & using on ATT.
    I have an unlocked N10+ but I flashed the ATT firmware. I get such lousy cell reception in my home, it was a must that I have wifi calling. Also I got back VoLTE, HD Voice, and Visual Voicemail. Cell reception is way better with the ATT firmware (even without wifi calling) so I'm OK with all of the bloatware.Need Preferred Network Type settings for Note10+ on ATT-device-info_att_20191022-191117_settings.jpg
    10-22-2019 08:16 PM
  6. bls819522's Avatar
    The area I also live in I have poor reception, can I flash my Note 10? How would I do this?
    10-22-2019 11:07 PM
  7. mustang7757's Avatar
    Yes definitely, you have unlocked version?
    10-22-2019 11:24 PM
  8. surfinguru2000's Avatar
Name:	Device Info_ATT_20191022-191117_Settings.jpg
    Thanks burrzoo. That's currently what I'm using. Now if only ATT would get their ish together and get these phones some VoLTE provisioning.
    10-24-2019 04:33 PM
  1. Deleting sent photo on whats app
    By Destiny-Di in forum Android Apps
    Last Post: 10-19-2019, 02:00 AM
  2. How to delete sent photo on whatsapp on my Gallaxy S5
    By Destiny-Di in forum General Help and How To
    Last Post: 10-17-2019, 02:22 PM
  3. How to delete sent photo on whats app on my S5
    By Destiny-Di in forum Ask a Question
    Last Post: 10-17-2019, 01:31 PM
  4. How to delete sent photo on whats app on my S5
    Last Post: 10-17-2019, 01:30 PM
