Have you tried clearing cache,data, force stop the camera?Lately I've been getting this notification pop up when I try to use Live Focus. It doesnt seem to go away u less I reboot my Note10+.
Anyone else seeing something like this, or know how to get rid of it?View attachment 312332
Haven't seen picture message in the notification panel , which carrier?I did force stop, but it didnt matter. Had to reboot.
What mode in Live Focus were you using? Background Blur, Find a Face, Spin, Zoom, or Color Point?
Are you using HDR?
To get rid of it try slowly sliding the notification to the right until you see the Gear icon. Select it and turn off "show notification" .
I how this helps.
Yeah never seen that messageAT&T
Any Live Focus mode, but mostly color point and the main live focus filter
I am using HDR, but I dont want to just silence the notification. I've never seen this before, so I'm worried there's an issue with my camera app.
Are you saving to an SD card? If so, set your camera to save to the phone and see what happens. It's possible that your SD card is going bad, or got corrupted.
Saving local/to phone
Have you tried other camera apps? I suppose the camera app can be corrupted somehow. Unfortunately, I couldn't replicate your problem.
Have you taken it to a local AT&T store and shown them?
Short of a factory reset (which I ONLY recommend as a LAST resort), I don't know what else to do that would fix the problem.
I got this message starting last nite and this morning it was still there. I did a reset and it went away. The only thing I did different prior to the message I took a photo by mistake using nite mode. Have no idea if this mattered but it was the only thing I could think of.
No, I dont use any other camera apps besides the stock app.
I didnt take it to a store because I doubt they'll be able to do anything, especially for, what I'm pretty sure is, a software issue.
I'm not going to factory reset just yet. I'll test it out a few more times.
I've never seen thatLately I've been getting this notification pop up when I try to use Live Focus. It doesnt seem to go away u less I reboot my Note10+.
Have you trying going into safe mode to see if it still happens? If it doesn't do it in safe mode, most likely another app is causing issues.No, I dont use any other camera apps besides the stock app.
