Camera Notification
Serkle K
1,459
35
48
Lately I've been getting this notification pop up when I try to use Live Focus. It doesnt seem to go away u less I reboot my Note10+.
Anyone else seeing something like this, or know how to get rid of it?15034.jpg
kevinpleasants
687
73
28
Are you using HDR?
To get rid of it try slowly sliding the notification to the right until you see the Gear icon. Select it and turn off "show notification" .
I how this helps.
Serkle K
1,459
35
48
Haven't seen picture message in the notification panel , which carrier?
AT&T
What mode in Live Focus were you using? Background Blur, Find a Face, Spin, Zoom, or Color Point?
Any Live Focus mode, but mostly color point and the main live focus filter
Are you using HDR?
I how this helps.
I am using HDR, but I dont want to just silence the notification. I've never seen this before, so I'm worried there's an issue with my camera app.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,560
6,135
113
AT&T
Yeah never seen that message
anon(7901790)
2,403
Saving local/to phone
Have you tried other camera apps? I suppose the camera app can be corrupted somehow. Unfortunately, I couldn't replicate your problem.
Have you taken it to a local AT&T store and shown them?
Short of a factory reset (which I ONLY recommend as a LAST resort), I don't know what else to do that would fix the problem.
Jax112
504
21
18
I got this message starting last nite and this morning it was still there. I did a reset and it went away. The only thing I did different prior to the message I took a photo by mistake using nite mode. Have no idea if this mattered but it was the only thing I could think of.
Serkle K
1,459
35
48
No, I dont use any other camera apps besides the stock app.
I didnt take it to a store because I doubt they'll be able to do anything, especially for, what I'm pretty sure is, a software issue.
I'm not going to factory reset just yet. I'll test it out a few more times.
msm0511
Trusted Member
Aug 23, 2014
4,619
9
38
You're definitely not alone in this issue. In my incessant refreshing of the Members app looking for the Android 10 beta I noticed others in the Community forums have it too. I followed the thread and will post back here if somebody there finds a solution.
anon(7901790)
2,403
I've gotten this in Night mode, but it cleared once it was done. Night mode cranks up the ISO and slows the shutter speed down. It then runs noise reduction during the processing. The amount of data being processed due to the slow shutter and high ISO means it has to work harder and it will take longer to process an image taken in Night mode.
I rarely use Night mode. I've found that the standard Photo mode works better for night shots than Night mode does.
anon(7901790)
2,403
Based on the previous response. Do you find this happening more often in Night mode?
Mike Dee
Ambassador
May 14, 2014
23,368
192
63
Have you trying going into safe mode to see if it still happens? If it doesn't do it in safe mode, most likely another app is causing issues.
Serkle K
1,459
35
48
I'm thinking it's something to do with Live Focus Mode. I just took a few Night Mode pictures while I was walking my dogs, and the message didnt pop up.
dedehammac
