11-12-2019 05:02 AM
27 12
tools
  1. Hesham Helal's Avatar
    Hey all,
    I have been recently downloading all of my apps one app at a time from the play store as i am not willing to migrate all the apps from my s8 plus, so when i am doing so while connected to the wifi, i have realized that my phone warms up and starts losing battery faster than usual, is that normal??
    TLDR: my phone warms up and loses battery fast when downloading multiple apps at a time from the play store
    11-08-2019 02:23 AM
  2. B. Diddy's Avatar
    That's pretty normal in my experience, especially if you're installing a lot of apps. It doesn't matter if you're doing them one at a time vs. having them all queued up as a large group.
    11-08-2019 02:41 AM
  3. Hesham Helal's Avatar
    Aha makes sense then. The thing is i panic whenever the battery is behaving in a weird manner, just because as i mentioned in my previous threads, i tend to leave my phone off for extensive periods of time before switching it on again, so i am always worried that would dsmage the battery. Plus when i switch it back on again after 15 days and lets say it was off at 80 percent , i find it at 79 percent battery and then for the first few minutes of it being switched on (5 min or so) it drops to 76 ir 75 percent does that make sense?
    11-08-2019 02:53 AM
  4. B. Diddy's Avatar
    That's also not that surprising. The phone is probably ramping up certain processes (like various apps syncing data) right after you turn it back on again.
    11-08-2019 03:09 AM
  5. Hesham Helal's Avatar
    Yea i thought about that too, what about it losing 2 percent while being off??
    11-08-2019 05:11 AM
  6. Hermes Hidayat's Avatar
    off as in turned off?or screen off?
    11-08-2019 05:15 AM
  7. Hesham Helal's Avatar
    Switched off, completely
    11-08-2019 05:16 AM
  8. Hermes Hidayat's Avatar
    Lets say you turn it off for 8 hours with 100% of battery. And when you turn it back on it shows 98% for instance. Its normal. If im not mistaken, turning it completely off and turning on airplane mode(cellular/wifi/bluetooth off) doesn't make a huge difference.
    11-08-2019 06:36 AM
  9. Hesham Helal's Avatar
    But why, i mean the phone is off so nothing is running at all not a single process i guess
    11-08-2019 06:38 AM
  10. Hermes Hidayat's Avatar
    Erm... It has a clock thus it uses a bit of battery. And booting up a phone drains battery as well...
    kct1975 likes this.
    11-08-2019 06:44 AM
  11. jeetu4444's Avatar
    If I remember...on my windows phone rebooting the phone would drains few % of the battery....how new is your Note 10 plus ?
    11-08-2019 07:40 AM
  12. kct1975's Avatar
    I too have noticed that with every smartphone I have owned, that booting it up from being completely off does seem to drain between 2% and 5% of the battery .
    11-08-2019 08:07 AM
  13. Hermes Hidayat's Avatar
    Different phones use different amount of battery to boot. For instance my N10+ uses 1%-2% of battery whereas my previous P30 Pro would use 0%-1% of battery. And depends on how long you turned the phone off.
    11-08-2019 08:49 AM
  14. Hermes Hidayat's Avatar
    I remembered rebooting my BlackBerry 9550 and it drained more than 15% of my battery hahaha.
    11-08-2019 08:50 AM
  15. Hesham Helal's Avatar
    My note 10 plus is 2 months old, I preordered it and received it as early as it was out
    11-10-2019 11:47 AM
  16. Hesham Helal's Avatar
    Aha, so when I see 2 percent less battery that's actually lost during the boot up??
    11-10-2019 11:48 AM
  17. Hesham Helal's Avatar
    Hey B.diddy,
    I have now experimented with my phone being idle and with wifi being off, but still I seem to get battery drain around 1 percent every 2.5 hours or so. What is your take on that
    11-10-2019 11:49 AM
  18. Hermes Hidayat's Avatar
    Not really. It depends on how long you kept it off. As battery loses juice even though its off.
    11-10-2019 11:55 AM
  19. Hesham Helal's Avatar
    Around 15 days
    11-10-2019 11:56 AM
  20. B. Diddy's Avatar
    Hey B.diddy,
    That seems normal, assuming you mean the phone is still powered on. That means the phone would still have a standby time of >10 days, which is impressive.
    11-10-2019 12:04 PM
  21. Hesham Helal's Avatar
    Yeah it is still on, but I am just baffled to what could be the cause of the drain when everything is off including the cellular tower connection
    11-10-2019 12:10 PM
  22. B. Diddy's Avatar
    There are still processes that run -- as far as I know, there's no way to completely freeze all system processes (and if there were, you might as well just power the phone down).
    11-10-2019 12:12 PM
  23. Hesham Helal's Avatar
    Yea I guess so too
    11-10-2019 01:18 PM
  24. Hermes Hidayat's Avatar
    Around 15 days
    What the heck hahaha. So its like you turned the phone off with 100% of battery for 15 days. When you turn it back on the battery is 98%?thats very normal hahahaha. So per month its 4%.
    You could actually turn your phone off for a year and have 52% of battery left!!! Hahahaha.
    11-10-2019 06:22 PM
  25. Hesham Helal's Avatar
    Lol yea, actually 81 percent and then I find it 79
    11-10-2019 11:46 PM
27 12
  1. NOTE 8: Blue tint on photos when i use flash
    By PaUi in forum Samsung Galaxy Note 8
    Last Post: 11-12-2019, 12:28 AM
  2. Note 10+ Scratch Test
    By cardboard60 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-11-2019, 05:35 AM
  3. Screen Off Notes App
    By David Rosen in forum Android Apps
    Last Post: 11-07-2019, 10:39 PM
  4. How many items can the edge clipboard hold on the Samsung Note 10 plus?
    By Android Central Question in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-07-2019, 02:58 PM
  5. How many items can the edge clipboard hold on the Samsung Note 10 plus?
