12-21-2019 02:25 AM
250 123 ...
tools
  1. Mike Dee's Avatar
    It's here.... Sign up in Samsung Members App.
    Post your thoughts.
    Note: Seems to only be available on unlocked variants.
    11-13-2019 12:32 PM
  2. msm0511's Avatar
    Post your thoughts.
    Got registered. Now to do a backup before installing.
    mustang7757 and buzzy3970 like this.
    11-13-2019 12:37 PM
  3. mustang7757's Avatar
    11-13-2019 12:44 PM
  4. Mike Dee's Avatar
    Note 10+ Unlocked on VerizonNote 10 Android 10 Beta: Issues and First Impressions-screenshot_20191113-134726_software-20update.jpeg
    Bkdodger1 likes this.
    11-13-2019 12:48 PM
  5. mclarryjr's Avatar
    I probably should have done that but it's a little late now.
    11-13-2019 12:53 PM
  6. mclarryjr's Avatar
    First I was able to activate the new gestures and it worked for a couple of minutes and then it switched back to the buttons by itself. Now I'm unable to return to the new gestures, the option to select "more options" doesn't work. Anyone else having this issue?
    11-13-2019 01:03 PM
  7. mustang7757's Avatar
    If you had back up sync on you should be ok
    msm0511 and mclarryjr like this.
    11-13-2019 01:04 PM
  8. mustang7757's Avatar
    Dont forget to log in to UI beta app and post error there
    msm0511 likes this.
    11-13-2019 01:06 PM
  9. msm0511's Avatar
    I decided to do a Smart Switch backup to my MacBook Pro along with the cloud backup. Its gonna take forever b/c I have almost 11,000 songs on my 10+.
    mustang7757 likes this.
    11-13-2019 01:13 PM
  10. Relletti's Avatar
    Finally. Going to download it. How's it running so far on your devices?
    11-13-2019 01:13 PM
  11. mustang7757's Avatar
    Omg
    Like what song at number 100
    msm0511 likes this.
    11-13-2019 01:13 PM
  12. mustang7757's Avatar
    Running smoothly so far
    msm0511 and Relletti like this.
    11-13-2019 01:14 PM
  13. mustang7757's Avatar
    I like the new device care Note 10 Android 10 Beta: Issues and First Impressions-screenshot_20191113-141459_device-20care.jpeg
    11-13-2019 01:15 PM
  14. msm0511's Avatar
    Omg
    Worse. On 69 now, but hey at least that’s a good number. 😂🤪🤣
    11-13-2019 01:16 PM
  15. msm0511's Avatar
    Cancelled the Smart Switch backup so I could change the preferences to not backup music. Was taking too damn long! I’ve got it all on my MBP anyway. Should be able to download soon.
    Relletti likes this.
    11-13-2019 01:24 PM
  16. Relletti's Avatar
    I like the new device care Click image for larger version.
    That looks so much cleaner
    11-13-2019 01:31 PM
  17. chazglenn3's Avatar
    Only available on unlocked phones?
    11-13-2019 01:39 PM
  18. mustang7757's Avatar
    It does
    11-13-2019 01:47 PM
  19. mustang7757's Avatar
    I think so far
    11-13-2019 01:48 PM
  20. chazglenn3's Avatar
    That explains it. Thanks!
    11-13-2019 01:54 PM
  21. Mike Dee's Avatar
    So far no hiccups. Banking apps work, AA Works.
    11-13-2019 02:08 PM
  22. Mike Dee's Avatar
    It changed the Google Bar. Note 10 Android 10 Beta: Issues and First Impressions-screenshot_20191113-151048_one-20ui-20home.jpeg
    11-13-2019 02:11 PM
  23. mustang7757's Avatar
    It changed the Google Bar. Click image for larger version.
    Nice haven't checked that yet
    11-13-2019 02:13 PM
  24. msm0511's Avatar
    Mine didn't change. How do you get it to show the Assistant stuff on the right? Mine says "Say Hey Google" and has the microphone.
    11-13-2019 02:19 PM
  25. msm0511's Avatar
    Haven't had time to mess with much, but I can say the new gestures are so much better!!
    11-13-2019 02:20 PM
250 123 ...
  1. LG Smartphone denying access to Android application??
    By zllo9 in forum General Help and How To
    Last Post: 11-16-2019, 09:46 PM
  2. downgrade android 5.1.1 from galaxy Tab a 7 inches
    By Nicholas Dendrinos in forum Ask a Question
    Last Post: 11-16-2019, 09:39 PM
  3. My snapchat crashes my phone Note 10
    By Goldbromc in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-14-2019, 09:21 AM
