1. CemicSuns's Avatar
    (If this might have accidentally been double posted, may I please ask the mods to correct this issue? When I posted the first time, it gave me a parsing error...)
    Guys, I have another question on my mind....
    I know Samsung decided to ditch the dedicated 3.5mm headphone jack, which still seems like an asinine decision to do with all carriers in general, and if we want to still use those signature earbuds, we need Type C to 3.5mm adapters with DAC (digital to analog converter) chips to use them as normally.
    I know Samsung has their own signature adapter which arguably offers the best quality. There's also the Google version, but I've heard complaints about it being too loud and has hiss. As for acquiring ones through eBay...this is hit or miss. Some might work, but others won't work.
    I found these on eBay, but I'm not sure if these would work... https://www.ebay.com/itm/174021137503
    For those who use the Type C to 3.5mm adapters, which ones would you recommend that best work with the Note 10+?
    And would these work as well as USB-C earbuds or wireless/Bluetooth earbuds?
    11-19-2019 07:44 AM
  2. mustang7757's Avatar
    I found these on eBay, but I'm not sure if these would work... https://rover.ebay.com/rover/1/711-5...2F174021137503
    Those would work , or can go with name brands from Amazon . Those wouldn't work with usb c headphones as they don't need a adapter but they work with regular headphone that need a 3.5 port. Bluthooth headphone won't use that either as they go through bluthooth of the phone.
    11-19-2019 08:24 AM
  3. CemicSuns's Avatar
    The CoolSell ones I showed on eBay would work with the Note 10+? I want to double check and make sure these would would be compatible. Ebay's very hit or miss. While there are some dongles which are just as effective as name brands, if not potentially better, there are some knock offs and fakes.
    If these work, this should allow me to use roughly any 3.5mm earbuds, correct?
    As for wireless/Bluetooth, those might wait for a different time so I can have wired and wireless as options.
    11-19-2019 09:31 AM
  4. mustang7757's Avatar
    Yeah will work with 3.5 headphones, if you worried about eBay can try Amazon that's where I usually shop for these things at great prices
    11-19-2019 09:35 AM
  5. lonestar1135's Avatar
    Google one from Best Buy works for me
    11-19-2019 04:48 PM
  1. Samsung Pay on Note 10+
    By Rw1016 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-21-2019, 05:17 PM
  2. S-Note Questions
    By daninbluemd in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-20-2019, 04:59 AM
  3. Full Screen Youtube shrinks to Picture in Picture at random intervals
    By Jason Wu Hunter in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-19-2019, 11:00 AM
  4. Connect Note10+ to external speakers on DeX?
    By Thatguyskyy y in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-19-2019, 08:52 AM
  5. Which USB-C to 3.5MM Adapters Work Best with the Note 10+?
    By CemicSuns in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-19-2019, 08:28 AM
