1. MichaelDiggs's Avatar
    Don't get me wrong, love my Note 10 + but I have a problem. I have the Pitaka case. It is pretty much bullet proof and is VERY slim. The problem is the case has no girth on the sides and I'm ALWAYS hitting the screen by just holding the phone since the screen goes all right to the very edge of the case. I see lots of cases out there. I do like the slim style cases, but I am looking for one that has some girth on the sides so when I hold it I am not always accidentally hitting the screen. When I eventually take the phone out of my pocket I could be three screens into something accidentally. Can anyone recommend a good quality case that gives me some grabbing room on the sides and preferably has a metal plate so I can still use my Pitaka magnetic wireless charger. I would sacrifice the magnetic charging for a really good case. I appreciate any recommendations. Thanks.
    11-21-2019 09:29 PM
  2. cardboard60's Avatar
    You ever look at speigen?
    Galaxy S10 Case Collection – Spigen Inc
    https://www.spigen.com/collections/galaxy-s10
    Or a UAG case.
    The Best Galaxy Note10 Plus Case from UAG - Rugged, Slim Protection – URBAN ARMOR GEAR
    https://urbanarmorgear.com/products/...ote10plus-case
    11-21-2019 09:41 PM
  3. mjs2011's Avatar
    Get the Official Samsung Rugged Case for sure. Very comfy to hold and the side has grippy ridges.
    11-21-2019 09:58 PM
  4. MichaelDiggs's Avatar
    Awesome. I have heard of Spigen and always liked their stuff, so I ordered the tough armor and hybrid and also the Samsung Rugged which looks really good. I use Amazon so I'll return the ones I do not use.
    11-21-2019 10:18 PM
  5. Bosbouer's Avatar
    UAG monarch may fit your requirements.
    11-21-2019 11:28 PM
  6. comptechltd's Avatar
    I don't have a Note 10 yet but I've used the Unicorn Beetle by Supcase on my past 3 phones and on a tablet and I love it. Perfect case for me.
    11-22-2019 08:58 AM
  7. MichaelDiggs's Avatar
    I just checked their website. I see that case and it does look like an OtterBox Defender wannabe but I do see a picture where there is a cut out for the top speaker grill. They might know exactly what they are doing.
    11-22-2019 11:04 AM
  8. amyf27's Avatar
    I've used the Uag Monarch on past phones and LOVE it. It is slimmer than the Defender noticeably, but provides great protection and grip as well.
    11-22-2019 02:27 PM
  9. cardboard60's Avatar
    I used to use otterbox defender cases.
    Found out.
    They are too expensive.
    Too big, and too bulky.
    Hope you find a case you like, both speigen, UAG.
    ANd ⁰encased has some good but not expensive cases on the internet.
    Good Luck.
    11-22-2019 03:06 PM
  10. trucksmoveamerica#AC's Avatar
    I just bought this one myself. So far, I'm liking it. I usually use the UAG plasma. Either one would be good
    11-22-2019 03:34 PM
  11. Super Dave426's Avatar
    I really like my clear Spigen hybrid, it has a tacky feel to it, never slides around in my hand.
    11-22-2019 07:57 PM
  12. strikeIII's Avatar
    DBrand Grip case is nice. And customizable.
    https://dbrand.com/shop/grip/galaxy-...cUvbUpU6694786
    11-22-2019 11:29 PM
  13. Vizi's Avatar
    The SPECK PRESIDIO GRIP CASE is great. Case with some grab on sides for Note 10 Plus-20191123_065103.jpeg
    11-23-2019 06:53 AM
  14. MichaelDiggs's Avatar
    I will have some results today. I have several cases coming today and can't wait to try them out. Can't wait to stop hitting the screen by just carrying the phone in my hand.
    11-23-2019 12:50 PM
  15. o4liberty's Avatar
    Otterbox symmetry case works awesome.
    11-23-2019 01:17 PM
  16. MichaelDiggs's Avatar
    Well, I received the OtterDefender, Samsung Rugged, a Spigen which did not open since I knew it would be to thin on the sides, and an Otter Commuter. So far I like the feel of the Otter Defender, which I didn't think I would. But I could actually pick up the phone and handle it normally without hitting the screen by mistake. Then I wanted to try the Commuter because that seems to be step down from the Defender and might take away the bulk. Stupid me somehow ordered one for an S10 Plus. The replacement should be coming today along with the UAG one which I really want to try. I'm surprised no one has the same problem with the Note 10+. Since the screen drops right down to the sides it is almost impossible to handle it without hitting the screen and going into apps by mistake. If you have it in your pocket and grab it you are definitely going to hit the screen for sure. Since the phone would be unlocked because it is on your body. Anyway can't wait to try the Commuter series and that UAG model. I did also order an EGO Case
    https://www.amazon.com/gp/product/B0...cUvbUpU6695446
    which I think is an UAG Monarch but was not sure but ordered anyway since I liked the case design. So if that UAG is a little less bulkier than the Defender that could be the model I need. In a few hours I will know for sure. Sorry, could not figure out how to put a URL on text.
    11-24-2019 11:19 AM
  17. trucksmoveamerica#AC's Avatar
    https://www.amazon.com/gp/product/B0...cUvbUpU6695683
    It's not the monarch. Look at both side by side and look at the bottom. The monarch has a curve going upward in the middle. Think it's the UAG plasma. Makes since.. The seller is third party adding the design. The monarch is the same price as what the seller is charging, so there's no money to be made, and the monarch has leather on the back, probably wouldn't work well with the design.
    I'm curious as to what you think of it, I've been looking at those. The plasma is a good case also.
    11-24-2019 08:17 PM
  18. MichaelDiggs's Avatar
    Did receive the UAG Monarch today. The case is a one piece very strong case. Phone seems well protected. I did use it pretty much all day and fell into that same problem where I'm accidentally hitting the screen.
    How does everyone else take care of this problem? I also have a work Iphone using a nice Sedieo case. I did notice that my Note's screen is ALWAYS unlocked and the Iphone is not. So I need to find out how to keep my Note always locked no matter if it's on my body, in my house, anywhere. The Iphone fingerprint sensor is one of the best and does work fast, the Note one is a little slow so I will try using the facial recognition. Now I'll just configure my note for screen on display always and to be locked most of the time. Maybe that's the problem, who knows.
    Also was not impressed by the expensive Samsung Rugged. Very slippery and just felt cheap plastic on the back. Took me just a few minutes to figure that out.
    11-24-2019 09:43 PM
  19. trucksmoveamerica#AC's Avatar
    Check your settings
    There's 2 settings you need to check
    Accidental setting touch..
    Turn off screen in pocket
    11-24-2019 09:51 PM
  20. trucksmoveamerica#AC's Avatar
    https://dbrand.com/shop/grip/galaxy-...cUvbUpU6696300
    Dbrand is running a half price sale on the grip cases.
    strikeIII likes this.
    11-25-2019 08:44 PM
  1. Anyone Know of Any Sales for the Otterbox Defender Pro Case for the Note 10+?
    By CemicSuns in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-28-2019, 08:42 PM
  2. Email App for S10
    By HnLA in forum Samsung Galaxy S10 & S10+
    Last Post: 11-28-2019, 07:31 AM
  3. Sync Calendar and Contacts with Win 7 ?
    By DUTCH VanAtlanta in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-26-2019, 08:28 PM
  4. How to restore a note from samsung notes
    By uraniumhexoflorite in forum Ask a Question
    Last Post: 11-21-2019, 11:13 PM
  5. What phones are supported on android 10
    Last Post: 11-21-2019, 06:40 PM
