Is it possible to Disable the Samsung Cloud app? Also, have already tried wiping the cache partition?
Once you clear data,cache and force stop it , you wont know if it good until the next reset of battery cycle.Hi
I have tried everything to fix this issue but it has been persistent for more than a week now. Have tried restricting background activity, forced stop, turned off sync etc...
Any help guys
Are you using Samsung Cloud actively? If not, try clearing its app cache/data as well, and then don't touch it.
