1. CemicSuns's Avatar
    (If this was accidentally double posted, may I ask the mods to merge the threads together? Thank you in advance, but I keep getting these errors whenever I ask a new question for some reason...)
    This has been a very pressing question on my mind.
    I know we need USB-C to 3.5mm adapters with built-in DAC chips to work with the Note 10+ to use 3.5mm earbuds, or we could use USB-C earbuds with DAC chips as well.
    But one thing has been on my mind...Wouldn't these cause damage to the C port for the Note 10+ with additional use outside of recharging the battery? If the C port gets damaged or corrupted, then the Note 10+ pretty much becomes dead because it can no longer be recharged, and without any insurance or coverage plans, you'd have to pay out the wazoo for a new phone.
    For those who use either USB C earbuds with the Note 10+ or use the USB C to 3.5 mm dongles, have they, or do you notice any damage done to the Note 10+'s C port?
    This is a question I want to ask as it's making me debate on wired vs. wireless earbuds for the Note 10+. Of course, with Bluetooth, I wouldn't have to worry about the phone's C port at all.
    11-24-2019 01:53 PM
  2. B. Diddy's Avatar
    I deleted your previous duplicate. Not sure why you're getting the errors when trying to post -- are you using one of the apps or the desktop website?
    11-24-2019 03:33 PM
  3. CemicSuns's Avatar
    Desktop.
    11-24-2019 03:52 PM
  4. B. Diddy's Avatar
    Not to sidetrack your main question, but what does the error message say?
    11-24-2019 03:55 PM
  5. CemicSuns's Avatar
    Can't fully remember it, but I think part of it involves parsing errors and stuff. I run Windows 10 on desktop.
    11-24-2019 04:05 PM
  6. B. Diddy's Avatar
    I think I've seen that as well. It might just be a temporary server glitch.
    11-24-2019 04:10 PM
  7. CKwik240's Avatar
    I haven't seen much complaint about USB-C ports having wear and test issues in general. Though, it's still a relatively new port. I mainly use wireless charging with my phone and haven't used the USB-C buds enough times to really get a good grasp of it. My work laptop charges via USB-C though and I am constantly switching between my port replicator at my desk and my charger when I'm in long meetings and I haven't had any issues.
    Frankly, USB ports are designed to be plugged and unplugged often so I don't anticipate any wear and tear issues. I'd really only expect to see ports loosen up on a board if it frequently sees excess external forces placed on it.
    11-25-2019 02:48 PM
  8. Rukbat's Avatar
    A USB-C plug has a long shell, keeping it from applying much pressure inside the connector, but if you handle it roughly, sure, it will get damaged, just like any tiny part. But if you're careful plugging the dongle in, and don't pull or yank on the cable (or drop the phone with the earphones firmly on your head or in your ear - putting a lot of stress on the dongle), you shouldn't have any problem.
    11-25-2019 06:04 PM
  9. matther22xdroid's Avatar
    The flimsy audio adapter won't bother the port. Nylon braided "tough" cables that are thick and don't bend easily WILL damage your charging port, that's even considering I always use a wireless charger at home, I'm having to send mine to Samsung for repair this week for that reason. My Note 9 and S9+ also had the exact same issue. Apples lightning port is perfect as it has no internal parts to loosen up, my wife has never had issues with any of hers.
    12-31-2019 09:00 AM
  10. Hermes Hidayat's Avatar
    You can charge with Wireless Chargers... I doubt it will be damaged in 2 years time... Unless everyday you plug and unplug more than 100 times...
    01-02-2020 02:25 AM
  11. j_hansen's Avatar
    If you always use original cables it won't be a problem but cheap China ones might not have the same tight tolerances and could easily promote premature wear of the port, besides all sorts of other risks
    01-02-2020 03:48 AM
  1. I'm disappointed in the P4...and mad at myself for wanting one.
    By Shadnic in forum Google Pixel 4 & Pixel 4 XL
    Last Post: 11-26-2019, 09:35 PM
  2. Google Pay: Where Did the 'G' in the Status Bar Go?
    By Father Tech in forum General Help and How To
    Last Post: 11-26-2019, 12:01 PM
  3. Where is located the antenna on my Moto cell phone by Motorola?
    Last Post: 11-25-2019, 03:22 PM
  4. How To Backup My Note 10+?
    By DUTCH VanAtlanta in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-24-2019, 03:54 PM
