1. cosine12's Avatar
    I got my Note 10+ on Sunday, I put it on my wireless charger before going to bed just like I did with my Note 8. On Monday morning I noticed that it didn't charge, I assumed that I either knocked if off center in the middle of the night or failed to place it properly. Last night, I was very careful to place it, it showed that it was charging before and after the screen when off. I woke up at 4AM and noticed that the light on the pad was flashing and sure enough it hadn't charged. I again set it carefully and noted that it indicated that it was charging before going back to sleep. When my alarm went off at 6AM I again notice that the light is flashing and sure enough it didn't charge any more. I again am very careful to place it and make sure that it indicates that it is charging and lay back down for a few minutes. About 5 minutes later I get up and the light is again flashing.
    It does charge just fine with a cable. This is the wireless charger that I have: https://www.amazon.com/Samsung-Wirel...cUvbUpU6696751 I have used this for about 2 years with my Note 8 without incident.
    Has anyone else had this issue? If so, how did you solve it?
    11-26-2019 02:12 PM
  2. SpookDroid's Avatar
    Have you tried other chargers? Wireless pads that were OK with older phones might not work with newer ones. Some are finicky even with the charger you're using to plug the wireless pad with.
    11-26-2019 03:02 PM
  3. msm0511's Avatar
    Also, what kind of case are you using? I know some cases can interrupt wireless charging.
    11-26-2019 03:03 PM
  4. j_hansen's Avatar
    Samsungs official wireless chargers has always been notoriously weak and sh1te at charging anything with even the most minimalistic case on, take your case off when using that charger or buy something like an Anker or similar with dual or triple coils in it
    11-26-2019 03:35 PM
  5. cosine12's Avatar
    I have not, but will see what it does on my wife's wireless charger when I get home. The charger that I have my wireless pad plugged into is the Samsung fast charger that came with the pad.
    nuangel2 likes this.
    11-26-2019 04:10 PM
  6. cosine12's Avatar
    It is a UAG Monarch, the same case I had on my Note 8. I will try it without my case and see if that makes a difference.
    11-26-2019 04:11 PM
  7. cosine12's Avatar
    I didn't have a problem with my Note 8 with basically the same case, but I will give it a try and see what happens.
    11-26-2019 04:15 PM
  8. Ruben Ocasio's Avatar
    It does charge just fine with a cable. This is the wireless charger that I have: https://www.amazon.com/Samsung-Wirel...cUvbUpU6696824 I have used this for about 2 years with my Note 8 without incident.
    It's the charger, will show you it's charging but like 5 to 10 min it will stop charging the phone especially if use a case like Amarillo Tek , so what i did was use a different Samsung charger and all works with no issues.
    11-26-2019 05:15 PM
  9. Ruben Ocasio's Avatar
    It does charge just fine with a cable. This is the wireless charger that I have: https://www.amazon.com/Samsung-Wirel...cUvbUpU6696829 I have used this for about 2 years with my Note 8 without incident.
    This is the one i use with Amarillo Tek case and UAG Monarch and UAG Plym. And works with no issues at all. New Note 10+ Not Charging Wirelessly-20191126_152029.jpg
    11-26-2019 05:24 PM
  1. New phones
    By gray2018 in forum General News & Discussion
    Last Post: 12-20-2019, 10:46 AM
  2. Pixel slate not connecting to an access point
    By Ricky Wood1 in forum Pixel Slate
    Last Post: 11-28-2019, 02:06 PM
  3. Photos on SD card not visible
    By speedfreek64 in forum HP Chromebooks
    Last Post: 11-27-2019, 02:24 PM
  4. Google Play will not stop updating
    By android_freak1 in forum Samsung Galaxy S10e
    Last Post: 11-26-2019, 12:08 PM
  5. Screen rotating while charging/standby
    By Nofear01 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-26-2019, 05:54 AM
